Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 10:38 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel is starting off with a positive reputation.
What is decent oil pressure for a broke in warm 351W?
Hey guys, got a question for ya. In my 89 Ive got the 5.8L. When its cold, the oil psi reads roughly 55-57psi oil (mechanical guage) But as I drive it and things warm up, the pressure steadily drops to only about 13psi at idle (800rpm) and around 25-30psi at 2k rpms. Is this normal? The engine has a brand new stock oil pump 3 years ago, and has roughly 110k mi on it. I try not to let the engine rev over 5k rpms when im off road, but it has happened a time or two. So yeah, is this normal, and would I be safe modifying the top end, or should I hold off and wait until I can get a complete rebuild before doing anything up top? Thanks for the help, Ill try and answer any questions best I can!
__________________
1989 F250 4x4, 351W, ZF S542, 4:10s, Upgraded to Dana 50 TTB front, 4" suspension lift 33" street, 38" swampers for when things get crazy!
1995 F150 4x4 300 I6, M5OD, 188000mi Daily Driver! SOLD!!!
1995 F150 4x4 302 auto, 6" suspension lift, 33" tires 67k mi NEW Daily Driver
http://www.ford-trucks.com/forums/image.php?type=sigpic&userid=207478&dateline=12337  01805
  #2 (permalink)
Old 11-04-2009, 04:45 PM
airharley's Avatar
airharley airharley is offline
airharley is gaining momentum as a positive member of FTE.
According to all the ford factory manuals I have read, at 1200 RPM the oil should be 10 PSI minimum. Scares the heck out of me sometimes when I have to state the factory specs. Over time all the bearing surfaces wear and increase the amount of oil that flows out. Even .005 extra clearance on all the bearings equals a lot of pressure loss. You can also change the oil pump to help combat some of the wear in that as well and recover some of the oil pressure if you are willing to extend the time before an engine rebuild.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
Author of the disc brake article for 57-64 F-100's
  #3 (permalink)
Old 11-04-2009, 11:57 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
Well, what are you going to do? Use your truck like it's twenty years old. Fix things when they break, maintain things to keep them from breaking. It might go another 20 years before the crank/bearings let go from low oil pressure. Wait and do the whole thing all at once.
Use this ford part as a replacement: M-6007-C392RT
  #4 (permalink)
Old 11-05-2009, 01:21 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
10 psi per 1000 rpm is plenty.
  #5 (permalink)
Old 11-05-2009, 02:38 PM
jimbob21rc's Avatar
jimbob21rc jimbob21rc is offline
jimbob21rc is starting off with a positive reputation.
you should have about 35 psi at 2grand, you could take off the oil pump and clean the pickup or just get a new one if your concerned it may be in the pump but even with a new pump you will probally be using your old pickup so make sure its clean, ( you wouldn't believe the crap they can hold, mine was nasty).
__________________
JIMBOB
78 f100 351w
http://www.ford-trucks.com/user_gall...?albumid=32723
Tags
1989 , 289 , 351w , bearing , block , clearance , f150 , ford , increasing , normal , oil , pressure , punp , rod , small , specification , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
