1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 F250 4x4 first brake job
Old 11-03-2009, 09:23 PM
Firetrout's Avatar
Firetrout
Firetrout is offline
Well I must state that at 79,000 miles I had the front brakes done. I now am going to have the rears done at 90,000.
My question is should I buy new rotors or just have them turned? My fronts squeak sometimes, not too bad and were turned. I do tow a boat about 50 times a year.
Old 11-03-2009, 09:54 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
Seeing as it is your first job i would think the rotors should be ok. Check the minimum run-out, if their ok just have them resurfaced. Ocassional squeaking brakes doesn't mean you have a problem unless it's excessive and/or consistant
Old 11-04-2009, 07:26 AM
asonico's Avatar
asonico
asonico is offline
X2
x2 what Dave said. Measure the thickness with a digital caliper ($10 from Harborfreight). Replace it if the thickness is less than 1.417".
Tri865
01-22-2014 04:08 PM
broncobilly66
2004 - 2008 F150
08-22-2009 04:53 PM
jpatter
31
06-14-2004 05:43 AM
tyneff
1997 - 2003 F150
07-13-2002 06:40 PM
kodiak2
1997 - 2003 F150
05-13-2002 07:48 PM
Quick Reply: 2004 F250 4x4 first brake job
