Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-04-2009, 12:47 AM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE.
Well PinkyDemon, you should care, or not comment on things you don't know. Starting in 1997 MY the 5.4 and 4.6 engine was available in the f150 and F250 LD models. The OBS (old body style) F250 HEAVY DUTY and F350 Carried on with the older motors and the non intercooled 7.3. There was no 1998 model year heavy F250 or Superduty 250 or 350 of either Kind. The 1999 MY kicked off the Superduty lineup as an Early 99 model. Ford didn't anticipate the amount of confusion and overlap the F250 LD and F250 Superduty would have. After the 1999 model year, the F250 LD was discontinued, but the heavier brakes and axles ( I believe all F250 LD had the semi floating 10.5/10.25 axle), cooling, suspension, goofy 7 lug wheels and brake rotors carried on as the F150 7700, or heavy half f150.
The F250 LD could carry either a 4r70w transmission or a 4r100, so you need to do more investigation to even know if there is a POSSIBLITY. Sounds like you are guessing at a lot, regardless of what your friend told you. Is it 4x4 or 4x2, cab configuration, YEAR! Also, all Superduty models with a 4 speed automatic have the 4r100. This is SIMILAR but not the same as the E4OD trans.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #17 (permalink)
Old 11-04-2009, 03:09 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
aldridgec,
I tried to rep you for the "spot-on" information in your post, but I'm apparently in rep "time-out".
Anyway, you're "on-the-money" here.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #18 (permalink)
Old 11-04-2009, 12:24 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
Got him for you Marv. Those trucks were fairly popular down here. A local construction company used to order these F-250 LD trucks by the dozen for use in the field and they were great trucks.
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #19 (permalink)
Old 11-04-2009, 01:48 PM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
We used to call them f200's.
  #20 (permalink)
Old 11-04-2009, 01:56 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
I'm pretty much positive the F-250LD in 97'-99' has the 4R70W trans. This PDF tends to back me up. http://www.stangnet.com/images/stori...s/97-21-10.pdf
My neighbor has a 97'-99' F-250LD 5.4l they are out there and are basically an F-150 with a higher GVWR. Your going to want to put a 4R100 in a SD.
__________________
FS: Factory Tech Valve Body for 4R100 http://www.ford-trucks.com/classifie...ct/27799/cat/5
69,873,761 firearms owners killed no one yesterday....
  #21 (permalink)
Old 11-04-2009, 05:12 PM
aldridgec's Avatar
I'm not sure what part of the document supports that the F250LD only had the 4r70w. I didn't study it, but didn't see anything that popped out to that effect.
Unfortunately Alldata still thinks it's an E4OD in 97 and 98, which may be technically correct, I can't remember the exact year it changed over. As of 99 it calls it a 4r100.
Hmmm... so is my activant catalog. It lists the 4r70w and E4OD as available transmissions in 97 and 98 F250LD
Thanks Marv and John!
__________________
Chris
Current Vehicles:
  #22 (permalink)
Old 11-04-2009, 08:57 PM
Big J
2005 Ford F-250
Quote:
You betcha!
__________________
John
  #23 (permalink)
Old 11-04-2009, 08:58 PM
Pinky Demon Pinky Demon is offline
Pinky Demon is starting off with a positive reputation.
Well, we all don't know every little thing about these trucks, but in my long experience, I've never heard of a Light duty. The 7700 F-150 I have, knew a guy who had one. My bad, simple as that. But as for the lug pattern, I couldn't give a flyin' f***, because I've never seen a lug pattern indicate the trim level or engine type, aka, important things.
__________________
2002 F-250 - V10, Crew Cab, Short Bed, Lariat 4x4 aka My Lovely Big Girl.
Click HERE for my full review w/ pictures of the Banks Powerpack Exhaust System.
  #24 (permalink)
Old 11-04-2009, 09:02 PM
Crazy001's Avatar
Crazy001 Crazy001 is offline
2008 Ford F-250
Crazy001 has a good reputation on FTE. Crazy001 has a good reputation on FTE.
Quote:
Speak for yourself! Some of us know EVERYTHING!
__________________
Tom,
Current truck - 2008 F250 CC 4x4 PSD
Previous Fords:
2007 F150 Screw 4x4
2003 F150 4x4 r/c auto
  #25 (permalink)
Old 11-04-2009, 10:32 PM
Quote:
And the rest of us are currently gathering to eat you.
__________________
  #26 (permalink)
Old 11-04-2009, 11:33 PM
aldridgec's Avatar
It's all good. But just because you haven't seen it doesn't mean it doesn't exist. Like UFO's, bigfoot, elvis.....
Oh, and if you've ever had to deal with those dang 7 lug wheel's/rotors you would definitely understand how important they are! Otherwise you may be right, not really that important.
__________________
Chris
Current Vehicles:
  #27 (permalink)
Old 11-05-2009, 09:42 AM
Darrenigel Darrenigel is offline
1999 Ford F-250
My Garage
Darrenigel is starting off with a positive reputation.
I currently have a 1999 f-250 light duty for sale. It has a 5.4l and a 4r100 trans in it. aldridge is correct in his post about the years and differences.
Tags
1999 , 2003 , 2006 , brake , duty , f250 , ford , ld , light , lug , rotors , truck , wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
