I was looking at replacing the factory transmission cooler when I rebuild my transmission. I was just looking for input on what you guys have used with good results. I don't do a lot of heavy towing just a tractor and dual axle trailer that weigh about 8k lbs. I use this truck as a daily driver and want the trans to reach a operating temp when not towing.
__________________
96 Ford F350 7.3l Mods: just getting started with new downpipe and straight pipe 5" stacks.
I subscribe to the old adage that "The pen is mightier than the sword".....As long as I'm close enough to stab that SOB in the chest with my pen
yeah the true cool is a popular and recognized for doing a good job, i was going to get one too but a friend hooked me up with a trans cooler from a 6.0l. they're bigger than our stock ones and should do a little better. haven't installed mie yet since i am waiting on all the part for intercooler so i can install everything all at once.
__________________
1996 F250 CC Short Bed 7.3l, auto, 4x4, 3.55, 6637 mod, 6 pos. chip, fpr shim
Thanks guys, I found it (tru-cool 4739 max). Seems simple enough to install and not real pricey, it should handle more than I need for now but I definately need the bypass during the winter or the trans will take for ever to warm up.
Three out of four numbers isn't bad considering I installed it 3 years ago. Big improvement over the stock joke of a cooler. At first I just installed a Hayden cooler and when I heard about the true cool I added it also. Two coolers for those tuff pulls!
__________________ Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
I am thinking about ordering one too Can i delete my older tranny cooler and put the tru cool max in its place will it help keep the tranny cool the bigget load i have pulled with the truck is 15000 lbs and thats not often
__________________
Ronnie Warfield
1995 F 250 Turbo diesel reg cab 2wd
6637 mod, 3 inch dp, lost kitty, GPR mod, 120v idm, 2500 watt inverter
Maryland Chapter member
yes you can remove the old one and replace it with the true-cool. Or you can run it inline with another. But I would loose the stock (it may be plugged a little) and replace since your not pulling very often.
I love mine and the tranny temp difference tells me the tranny loves it too!
__________________
1997 F-350, 4X4, Standard Cab, Long Bed, 4.10's
the mounting straps that come with the tru cool will not hold up if you do a lot of dirt road driving! I started welding 1/4" X1" strap "shaped to fit" from the top of the core support to the bottom and run the cooler horizontally, I haven't had one brake this way yet. the last truck I did this on drives 20,000 + miles a yer on dirt roads and no problems yet.
__________________
They promise freedom, but they themselves are slaves of sin and corruption. For you are a slave to whatever controls you.
the little people who live behind my eyes and scream directly at my brain told me to tell you HELLO Diamond K your complete automotive and truck repair center
