Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 6.2L Boss
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
6.2L Boss Discuss the upcoming 6.2L V8
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 09:19 PM
Evan99's Avatar
Evan99 Evan99 is offline
2002 Ford F-250
Evan99 is starting off with a positive reputation.
HP/TQ Numbers
Just saw on pickuptrucks.com the 6.2L will have 411HP and 434 ft. lbs. of torque using reg fuel didnt say if was for both F-150 & 250 but thats the numbers for the F-150 for sure. Sorry if this is a repost.
What do ya think?
Heres the link
Ford F-150 SVT Raptor 6.2-liter V-8 Power Ratings Announced - PickupTrucks.com Special Reports
__________________
GREEN 2002 f-250 XL 5.4L Stick shift
LOVE IT!!
1989 F-150 302 Stick shift (my F-150 Raptor)
Been missing for a year or two
  #2 (permalink)
Old 11-04-2009, 12:19 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a good reputation on FTE. biz4two has a good reputation on FTE.
Thumbs up
Those are GREAT numbers for the 6.2L. I am sure...those are conservative numbers too. That engine has so much more potential...
What I have said in the past...is the 6.2L must provide more torque than my current V10 in order for me to consider it (wasn't concerned with hp numbers). If the numbers hold up...then my next 2011 or 2012 SuperDuty CC 4x4 will have the 6.2L.
Just in case any are interested...my '03 V10 has 310hp and 425ft/lbs torque.
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #3 (permalink)
Old 11-05-2009, 07:08 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Don't know how accurate, but :
6.2L V8
Max HP - 411 @ 5500 rpm
Max Torque - 434 @ 4500 rpm
6.8L V10
Max HP - 362 @ 4750 rpm (310 @ 4250(?) for 2-valve)
Max Torque - 457 @ 3250 rpm (425 @ 3250 for 2-valve)
Kinda what I expected. With 8 cylinders, versus 10, you're looking at 25% higher RPMs (or 20%?) to get the same peak torque numbers. Just about right.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #4 (permalink)
Old 11-05-2009, 11:21 PM
biz4two's Avatar
Arrow
Good info Krewat. Kind of makes me think...that gearing is going to be so important with the 6.2L...even more so than the V10.
I'm already thinking of going with the lowest gears they will offer, but just have to wait until that info comes from FORD. If I were a betting man, then I would think the 4.30...just like the V10.
biz
__________________
  #5 (permalink)
Old 11-06-2009, 12:33 PM
Krewat's Avatar
Anyone know what the 6-speed tranny ratios are going to be?
__________________
  #6 (permalink)
Old 11-06-2009, 03:50 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is gaining momentum as a positive member of FTE.
Info below pulled from this article:
First Look: 2011 Ford F-Series Super Duty - PickupTrucks.com Special Reports
________5R110___6R140
1st_____ 3.11_____3.97
2nd_____2.22_____2.32
3rd_____1.55_____1.52
4th_____1.00_____1.15
5th_____0.71_____ .86
6th_____----_____ .67
Reverse_-2.88____-3.13
Span___4.34______5.90
__________________
2000 F250 V10, sc, lb, 6.5in Pro Comp lift, Bilstein 5100's, 37in Toyo M/T's, 17in MT Classic II's, K&N FIPK, 3.5in B&B exhaust, Randy Ellis light bar, 4 - 8in KC 800 Series lights
Last edited by 2000silverbullet; 11-06-2009 at 03:57 PM. Reason: trying to format the chart so it's readable
  #7 (permalink)
Old 11-06-2009, 04:39 PM
Krewat's Avatar
Well, that'll let you get more grunt from a dead stop with less overall torque (and I suspect, a lower low-end torque than the V10 has) and combined with a taller rear gear, like 4.30's, still get some decent gearing on the highway empty.
__________________
  #8 (permalink)
Old 11-08-2009, 12:13 PM
strokinout strokinout is offline
strokinout is starting off with a positive reputation.
It sounds like with this new 6-speed that you can get away with slightly lower torque and still get good launch off the line with better fuel economy. More than likely that the tranny's what will make it a good replacement for the v10. I'm still confused to why it's available, but only in the chassis cab.
  #9 (permalink)
Old 11-09-2009, 01:06 PM
Krewat's Avatar
Quote:
I'm not
__________________
  #10 (permalink)
Old 11-09-2009, 01:33 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Ford probably won't offer 4.30s anymore just like they removed 4.10s from the list when on the new F-150s when the 6spd was added. I suspect Ford will want to put 3.73s in the gas SDs with the 6.2l and 3.31s in the 6.7l SDs. Ford revised these new 2011 SDs for gas mileage.
People whine about the 5.4l and 6.8l revving high, the 6.2l will be revving a lot higher. The numbers are good on the 6.2l but the rpm peaks are better suited for a mustang unless Ford really manipulates the curves with the VVT setup. Guess we'll have to wait to see the hp/tq curves when they come out. If Ford puts 4.56s behind the new 6spd/6.2l combo in the SD I think it would work good.
__________________
FS: Factory Tech Valve Body for 4R100 http://www.ford-trucks.com/classifie...ct/27799/cat/5
69,873,761 firearms owners killed no one yesterday....
  #11 (permalink)
Old 11-09-2009, 01:46 PM
dwrestle's Avatar
dwrestle dwrestle is offline
dwrestle is starting off with a positive reputation.
Yeah but the 5.4 the 6.8, and I'm sure the 6.2 all make good low end torque. The 5.4 and 6.8 make like 80 or 90 percent of their peak torque at like 1k RPM. You would think they would still offer low gears since the 6 speed pretty much has 2 overdrives.
__________________
1983 Ford F-150, Reg Cab, 300 six, probably 3.55's Black with red pinstripes.
Old Ford Rides: 06 F-150 XLT, Supercab, 4x4, 5.4, 3.73's, Treador Red(Awesome). 1994 F-150, XL, Supercab, 4x4, 5.8(with cam), 3.55's, Black(Awesome).
  #12 (permalink)
Old 11-09-2009, 02:01 PM
Quote:
Originally Posted by Krewat View Post
I'm not
I meant why only in the chassis cab. From what I can tell everyone who owns one loves 'em. It seems like they're going the route gm and dodge did where dodge dropped their v10 and gm dropped their 8.1. And anyone notice how they keep uping the displacements? From the way things keep changing, the powerstroke's heading closer and closer to 7.3l. King of ironic.
  #13 (permalink)
Old 11-09-2009, 02:13 PM
Krewat's Avatar
I suspect that it has more to do with emissions than anything else. Two spark plugs. Think about it
The chassis cab trucks are such high GVWR, they don't need to conform to newer emissions standards. Maybe because they don't have an EGR.
There's something magical about 2010 and trucks over (or under) 14,000 pounds.
__________________
Tags
2000 , 411 , 46l , 62 , f150 , ford , ford150 , gears , hp , low , raptor , shift , specs , stick , svt , tq , truck , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
