No power at trailer plug in. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-03-2009, 07:48 PM
Capitlj's Avatar
Capitlj Capitlj is offline
Capitlj is starting off with a positive reputation.
My older brother runs his own contracting company, and primarily uses his 05 F250 to pull his 25 foot enclosed trailer around along with skid loaders etc. The interior lighting for the trailer is run using the constant 12v power terminal of the 7 pin RV plug that his truck came with. This terminal has no power switched or constant. All the fuses are good, and the connector itself is in good shape, I also chased the wire back to the cab and it was fine. Looking over the wiring diagram in his chilton its 12v source is a trailer/tow relay, I am unable, however, to locate this relay in either fuse panel. Using the diagrams in the chilton and the owners manual proved useless, also switching the horn relay with all the others did not fix it or locate any bad relays. Anyone have any ideas what the heck is going on?
Old 11-03-2009, 10:41 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
It probably is a fuse, actually I think there is a couple that go to it. I used a little light bulb tester back there are just started checking fuses under the dash and under the hood.........took about 20 minutes.
Old 11-03-2009, 10:59 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
The fuse an relay are under the hood on the drivers side.
the owners manual shows the location.
we've had them blow when just hooking up a trailer with defective wiring .
Rich
Old 11-03-2009, 11:27 PM
Capitlj's Avatar
The wiring on the trailer is a possibility, but all the fuses were tested, I found one bad one and replaced it but still no powah. The relays were also tested by switching them all out with a known good one.
Old 11-04-2009, 02:16 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
This terminal is only "hot" when the engine is running.
Soooooo, is it running?
Pop
Old 11-04-2009, 06:59 AM
Capitlj's Avatar
Tried that too. There is no way for that terminal to only be hot when the engine is running however, as long as the key is in the on position, the engine might as well be running.
Old 11-04-2009, 07:13 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
there are two fuses.. one controls the relay itself and one that protects the wire to the trailer.. if you pull the relay do you get power at the two terminals?
inside the cab.
107 20A** Trailer tow battery charge
301 Full ISO relay Trailer tow battery charge
I don't see any labeling for the fuse to control the relay itself, but there must be one.. anyhow with the key on, there should be power at 2 of the relay terminals.. power off, only one.
sam
99' F-250 6.8L Fuel Pump Wiring question. Rhino99 Modular V10 (6.8l) 0 02-21-2016 06:11 PM
Need Constant 12v Power at Bed - Run Wire or Jump Relay KCBS Smoker 1999 to 2016 Super Duty 4 01-08-2016 07:35 PM
1982 F150 Horn Relay Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-18-2014 07:25 PM
Testing a relay??? RFD_Truckie Electrical Systems/Wiring 6 07-10-2009 06:00 PM
Trailer Running Lights DOA, Truck Lts wkg OK... Mark 42 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 03-08-2004 10:35 AM
Tags
2001, bad, battery, charge, diagram, f250, f350, f450, ford, fuse, plug, power, relay, relays, tow, trailer, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
