Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 08:39 PM
big_ford_rednek's Avatar
big_ford_rednek big_ford_rednek is offline
big_ford_rednek is starting off with a positive reputation.
flywheel imbalance and questions
was wondering the difference in flywheel imbalance on a 95 300 6. if my research is correct, there is either 0 imbalance or is internally balanced. can you add to a flywheel or just subtract weight? also, how much does it cost to add or subtract if possible. thanks derrek
__________________
1995 Ford F150 300 6cyl (soon to be 351w/zf5 spd) 4x4
http://www.ford-trucks.com/user_gall...id=206330&.jpg
  #2 (permalink)
Old 11-03-2009, 10:17 PM
300 Buster's Avatar
300 Buster 300 Buster is offline
300 Buster is starting off with a positive reputation.
I would kinda like to know about the balance on the 300s.Is it internal or is it on the harmonic balancer ? I think the flywheel is balanced by itself (not with the engine's internal parts) and should be done with the intended pressure plate mounted and marked for index.Every time I've had a pan off,I've forgot to look at the crank to see if it's drilled for balance.
__________________
'96 F150 4.9IL 5 Speed Stick
Tags
flywheel , ford , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
