Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 08:29 PM
River River is offline
River is starting off with a positive reputation.
Voltage gauge for 2006 F350 Super Duty?
Is there a real good, easy, nice fitting voltage gauge fpr my truck? It came with everything but that one, and I'm going on 3rd set of batteries now. Sure would love to know what's going on with my voltage FORD!
Would appreciate it if anyone has good suggestions. I hate tacky looking aftermarket stuff.
Thanks!!
  #2 (permalink)
Old 11-03-2009, 08:38 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
If you don't like the look of after market stuff, then your options will be pretty limited. You could upgrade to one of those fancy in dash radio / gps / kitchen sink things. The one my wife has in her truck can read voltage. (Pioneer Avic)
The other option would be just to drop $15 at wally world and get you one that plugs into the lighter socket that you can just remove whenever you don't want to see it.
I've checked the accuracy of that little thing with my scanner and the readings always match.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #3 (permalink)
Old 11-03-2009, 08:50 PM
Thanks, but my cig lighter has too many things plugged in to use it on a regular basis. Are there any where you can mount just the volt meter on the windshield pillar? I've seen triple gauge sets on the pillar, but never a single gauge.
  #4 (permalink)
Old 11-03-2009, 09:11 PM
F350-6's Avatar
Slow Typing
Sure. I've seen 1 - 4 pod mounts for the pillar. 03-07 6.0L Gauge Mounts
If it were me, I'd consider maybe adding just more than one gauge though. Factory gauges aren't always the most accurate, and there may be something else you'd like to accurately monitor. If not, the link above has a single gauge mount for the pillar, and Dennis is a good guy to deal with.
__________________
Chris
  #5 (permalink)
Old 11-03-2009, 09:24 PM
any recommendation on gauge brands?
thanks!
  #6 (permalink)
Old 11-03-2009, 09:35 PM
F350-6's Avatar
Slow Typing
I'd get one that blends in well and you like the looks of. Stick with any of the popular brands and you should be fine. Diprocol, Isspro, Autometer, etc. If you've got a 6.0, you could even go overboard and order one of Joey's gauges. Terminator Engineering
It will read voltage, along with a number of other things, as well as read trouble codes and run some tests.
__________________
Chris
  #7 (permalink)
Old 11-03-2009, 09:45 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
How about the stock voltage gauge? In trucks with the stock non upgraded odometer readout you can press and hold down the trip reset button. You have to have the key in the off spot press and hold down the trip reset button and while holding it down turn the key to the run mark about 15 secs and it will pop up a full DTC menu. You can see about 20 different DTC rpms voltage tps and so on. There is also a self test feature for the radio.
__________________
If it doesn't fit, FORCE it.
If it breaks, well, it needed replacing anyway.
  #8 (permalink)
Old 11-03-2009, 10:32 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is starting off with a positive reputation.
I think you should spend your money to diagnose your problem. Try using a DVM (there relatively inexpensive) for measurements while troubleshooting. Give us some more info on your problem so we can try to further help you with the situation.
__________________
"QUALITY IS BUILT-IN , NOT ADDED"
"06" F-250 XLT/SC/LB/FX4/5.4L/ 6-SPD man.
man.transfer & hubs/HD service front springs/rear swaybar/Line-X/"BLACK"
"04" Escape Limited/"BLACK"
"00" Mustang V6/"BLACK"
"71" Bronco, 302, "BLACK/RED"
"67" Fairlane 500 Conv./289 HI-PO/"RED"
Ohh Ya Almost Forgot-"96" Nissan Pathfinder/"BLACK"
  #9 (permalink)
Old 11-03-2009, 11:33 PM
There's no real issue to trouble shoot, it's just cheap batteries today. I have a dual setup and a large truck camper that I use several times a year. It never fails that you find one of the batteries failing just as I'm pulling out of the driveway for a trip. Of course you don't know which one it is. Without a voltage gauge, there's no way other than the dreaded slow or no start to know that one is going bad. Just looking for a little more 'insurance' as I pay pretty good attention to my gauges.
thanks!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
