Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 08:12 PM
Joe T. Joe T. is offline
Joe T. is starting off with a positive reputation.
'55 F-100 Cowl vent
Our '55 F-100 was a basket case. I see how the cowl vent "lid" bolts to the hinges. I see no other parts to make it function other than maybe a long rod with a sort of gear on each end. I'm assuming the vacuume type parts are for the wipers ? Any schematics or explanations appreciated.
Thanks, Joe
  #2 (permalink)
Old 11-04-2009, 12:05 AM
Randy Jack's Avatar
Randy Jack Randy Jack is offline
Randy Jack is gaining momentum as a positive member of FTE. Randy Jack is gaining momentum as a positive member of FTE.
If you buy a 1955 Ford Truck Shop Manual, all these kinds of questions are answered with pictures and full removal/install directions. This maunal can be found on eBay and many other sites.
__________________
Randy Jack
56 F100 Street Rod Daily Driver
Growing OLD is mandatory. Growing UP is optional.
Inside every old guy is a younger guy wondering what the heck happened.
  #3 (permalink)
Old 11-04-2009, 03:42 AM
Julies Cool F1's Avatar
Julies Cool F1 Julies Cool F1 is offline
Posting Princess
1951 Ford F-100
Julies Cool F1 has a good reputation on FTE. Julies Cool F1 has a good reputation on FTE. Julies Cool F1 has a good reputation on FTE.
Here's a drawing of the 56 vent - it's very similar if not the same.
Randy Jack has a good point - if you are going to restore you need to get the books. Also, there are lots of threads on this stuff if you use the search function.
__________________
Best wishes
Julie!
  #4 (permalink)
Old 11-04-2009, 03:53 AM
dawolverine dawolverine is offline
dawolverine is starting off with a positive reputation.
Mine was missing the open/close handle etc - I've just put an electric linear actuator on it rescued from under a modern car seat. Very easy to do and it works very well.
  #5 (permalink)
Old 11-04-2009, 03:46 PM
SCD SCD is offline
SCD is starting off with a positive reputation.
dawolverine
How about a picture of what you did? I have been thinking about doing this. What kind of car did you get the actuator from?
Thanks
Scott
  #6 (permalink)
Old 11-04-2009, 08:29 PM
Huntfamily53's Avatar
Huntfamily53 Huntfamily53 is offline
1953 Ford F-100
Huntfamily53 is starting off with a positive reputation.
Quote:
I am curious as well...I would like to see how it was done.
__________________
1953 Ford F100 Project
Building some family memories through empty pockets, busted knuckles, and muffled swear words!
  #7 (permalink)
Old 11-05-2009, 11:48 AM
Give me a day or two and I'll get some pics for you - I removed the actuator from a seat runner off a late model ford seat (I think its from an escort or similar). It works on a worm screw that pushes a small metal bracket forward - I trimmed the bracket end to match the cowl hookup point and bolted the two together with a spacer for clearance. I mounted the other end to a couple of little custom brackets I made up as my trucks dash brace was missing. I was surprised how easy it was to do to be honest, it only took me a couple of hours and that includes all thinking time
  #8 (permalink)
Old 11-07-2009, 02:43 PM
Ok, heres a side view from the passenger side of my install. There are a couple of other pictures on my photobucket site as well if you're interested. follow the link below then check out 'most recent uploads.
you can't see the mounting points on the pics but its basically a single long bolt on the bottom of the actuator which attaches it to the C-shaped channel. That channel then goes back to the dash where i flattened the end and bolted it. An 'L' bracket also attaches the dash end to the centre dash brace for stability. You can just make it out in the picture).
The silver upright has the worm screw inside that moves it up or down - I bolted that at the top to the original cowl bracket with a spacer. This allows the cowl bracket to pivot nicely as it lifts/closes. It all sits solid as a rock and works a charm.
The top angled brace holds up my wiper motor by the way.
Pictures by dawolverine - Photobucket
  #9 (permalink)
Old 11-07-2009, 06:06 PM
merten's Avatar
merten merten is offline
merten is starting off with a positive reputation.
That long rod with gear on each end is.........
Quote:
The rod connects the seat platform, for fore and aft seat adjustment.
__________________
  #10 (permalink)
Old 11-07-2009, 08:15 PM
Thanks for the info !! I was afraid that rod had to fit under the dash. Its bad enough trying to find a spot for a computer and Ron Francis fuse box.
Tags
cowl , ford , truck , vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
