Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 08:08 PM
fordboy098's Avatar
fordboy098 fordboy098 is offline
fordboy098 is starting off with a positive reputation.
throttle body spacer?
ok so i was looking under the hood of my 78 ford f250 anf i saw the guy i bought it from used a inch block of wood for a throttle body spacer. and i cant seem to fine one online. any suggestions?
  #2 (permalink)
Old 11-03-2009, 08:31 PM
thekingofcows thekingofcows is offline
thekingofcows is starting off with a positive reputation.
I don't even know what to say. He used a block of wood as a throttle body spacer? Was it to replace the egr valve plate?
  #3 (permalink)
Old 11-03-2009, 08:32 PM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
Probably not wood. Wood is not dense enough to prevent leaks, and wood is just not good.
Phenolic spacers look like wood but are not wood.
These do not transfer heat like typical aluminum units do.
You could have some difficulty looking for a throttle body spacer for a 78 truck because the truck has a carb and not a throttle body unit.
You should be looking for a "carb spacer".
  #4 (permalink)
Old 11-03-2009, 10:00 PM
fordboy098's Avatar
ahh ok i see thanks man. also i wanna lift this truck pretty high, they make 10 inch lifts for this truck correct?
  #5 (permalink)
Old 11-04-2009, 02:08 AM
75F350's Avatar
1973 Ford F-100
My Garage
Only custom springs for lifts this tall.
How much tire do you intend to run?
  #6 (permalink)
Old 11-04-2009, 11:08 AM
fordboy098's Avatar
im running 44 inch boggers on this, im guesing ill have to go higher if i dont want rubbing
Tags
body , spacer , throttle , wood
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
