I think there is a check valve in oil filter assembly. I know you have to release the oil filter B4 you drain the oil so the valve opens up and drains the oil back into the pan. This may be your problem.
Did you change your own oil? I have heard of non ford filters causing problems. Is your filter an Ford filter? Also there is a top and bottom to the oil filter. I don't know if you can install it upside down.
Just some things to check.
__________________
2005 Eddie Bauer 4x4 w/6.0 PowerSlot Cryo Rotors up front, Hawk LTS pads all around, Bi-Xenon HID's.
Who said size doesn't matter?
