ok truck is a 2006 f350 6.0 I have a sct programmer on it. and i was wondering why you cant get much past 20# boost. no matter what program i cant get past that. is it the turbo oris it like a plate limiting boost? never asked about it thanks
Yeah what tune are you running? The tunes I run will hit 30 and then drop down and I'm pretty sure the tune is limiting the boost which suits me just fine. Might be your tune or some sticking vanes or you got a leak. Any unusual noises?
__________________
05 F250 4" turbo back,ccv reroute
coolant filter 6" Fabtech lift, 35x12.50 MTZs
Isspro Gauges, ITP Fuel RR, EGR... well it was there a minute ago...
SCTX3 with innovative tunes, amp research
Airdog ARP studs
flash i dont know what you are talking about. and the egr system untouched. plan on buying the liberator delete kit soon. but ya today after i got the oil changed and still not much over 20# so i dont know.
Same truck, same programmer - never more than 20-22# of boost. Recently installed 4" exhaust and gained 8-10# of boost. Factory exhaust is that restrictive.
wow that is horrible. so what can you touch for boost now? looking at putting the egr delete then stacks that should open up alot more. thanks for the info
I had the same problem, the vanes on the turbo were sticking.
Ford did the updated housing, cleaning and I did a CCV reroute
to keep things clean. I hit 30-32 psi easy.
__________________ 2005 F350 4X4 King Ranchlong bed BF Goodrich KM2 Mud-terrain 35/12.50/R18, Bush-wacker's, level kit, ARP Studs, Accufab intake Elbow, SCT X3 with Spartin Tunes,Full EGR Delete, Pyrometer in a single pod,Full 4" Magnaflow turbo back exhaust with 5" tip w/ modified Cat to 4" inlet/outlet, Zoodad, CCV Re-Route
dont want to cross threads maybe a little info here what the ccv reroute is but somebody pm me the details and maybe a how to. ya when i get the new exhaust on i will let you know i believe the exhaust will be a 4 inch dp with 4 inch pipe to two 6 inch mitre stacks behind the cab 36 inches long
