Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 07:01 PM
whiteexc22 whiteexc22 is offline
whiteexc22 is starting off with a positive reputation.
Unhappy v10 excursion problems!!!
hey guys i need some help in a bad way...my excursion had been to 4 shops and has been sitting for 7 months now...when you drive the thing and pull up to a stop light or a stop sign and prepare to stop and when you do stop the motor lugs down to around 400 rpm and wants to stall and sometimes does and when you pull away it shifts down to first,so its like it stays in second while your on the break and when you let off the brake pedal and start to roll it shifts down...it also at an idle in park stalls and misses every once in a while...sounds like a machine gun sound at an idle....iac has been changed,,,maf has been changed,,,cops have been changed,,,,speed sensors have been changed.....check engine light is on but registering no codes? tranny shop ran the tranny for codes but came up with nothing....im at wits end trying to fig this out...could it be the main computer? i dunno whats left so hopefully someone out here can help
  #2 (permalink)
Old 11-03-2009, 07:16 PM
andym's Avatar
andym andym is offline
1989 Ford F-150
My Garage
andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation.
Quote:
If the computer isn't giving you codes then either there is a wiring problem between the PCM and the OBD connector, the reader doesn't work, or the PCM is bad.
So that's one problem. From your description is sounds like the torque converter is not unlocking when you come to a stop. The PCM controls torque converter lockup, so either the computer is not doing its job, it's getting bad information from a sensor, or it's not able to control lockup like it should.
I think you're right, you should probably replace the computer if you can't pull the codes from it after eliminating the other possible causes I mentioned.
__________________
Andy
Quote:
Nothing is obscene if we only close our eyes
  #3 (permalink)
Old 11-03-2009, 08:01 PM
thx for the reply.....i thought about the convertor but then why would it miss and stall why its in park....unless im having 2 diff problems....the scanner is a snapon computer and is not picking up codes so i was thinking that the trucks computer might be failing
  #4 (permalink)
Old 11-04-2009, 12:32 PM
andym's Avatar
1989 Ford F-150
My Garage
Unless the miss and stall are computer-related, which is certainly possible, then yes you have two problems. But I would fix the big one first, lots of times the smaller ones will go away when you fix the larger problems.
__________________
Andy
Tags
2008 , 99 , case , check , engine , excurrsion , excursion , ford , intermittent , light , miss , motor , problems , transfer , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
