Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 06:41 PM
farmdude farmdude is offline
farmdude is starting off with a positive reputation.
1956 y block 272 acceleration problem
motor bogs down when pressing on accelerator and holding the accelerator where the bog started it will catch up and reach rpm.
it is also hard to start after it sets a bit .
could a weak fuel pump cause these symptoms.
the unit i have is 1956 f600 272 cu. in holley 2bbl carb.
installed:
1 . power valve
2. carb bowl and meter plate gaskets
3. points are good
4. vaccumm lines - no leaks
5. fuel level in the bowl is just below the check hole.
man if anyone has ideas i wolld really like to hear them thanks alot
  #2 (permalink)
Old 11-03-2009, 09:02 PM
WALFORD'S 56's Avatar
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 is starting off with a positive reputation.
I have same truck,and had same problem and carb was rebuilt. It was the power valve.
Bill
  #3 (permalink)
Old 11-03-2009, 10:10 PM
brucewon's Avatar
brucewon brucewon is offline
1955 Ford F-100
brucewon is starting off with a positive reputation.
I had that problem on my 55 f100 and found out my battery was giving out. At low RPM it was ok but when I stepped on it it would start to bog. I had sears test the battery and they said it was bad. I replaced the battery and the problem went away. Good luck.
  #4 (permalink)
Old 11-03-2009, 10:55 PM
ghall ghall is offline
ghall is starting off with a positive reputation.
accelerator pump... or the one-way check valve in the cavity for the bog...
hard start after setting could be power valve diaphram
  #5 (permalink)
Old 11-04-2009, 07:03 AM
cbass139's Avatar
cbass139 cbass139 is offline
cbass139 is starting off with a positive reputation.
I agree with ghall, I just went through this with my 292 with a 2 bbl. I put in a new accelerator pump and made sure all the linkage was set right and tuned the timeing to be perfect and when I hit the gas, I go!!!!
__________________
"Nothing is particularly hard if you divide it into small jobs."
"Chop your own wood, and it will warm you twice."
-Henry Ford
  #6 (permalink)
Old 11-05-2009, 07:25 PM
i did the carb rebuild and found the accelerator check was stuck
runs alot better now , but still a little uneven at the top . will keep workin on it.thanks guys for the replies
Tags
1955 , accelaration , acceleration , ford , problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
