Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 05:58 PM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Rice Rocket Eater
Fullcrew7.3 is gaining momentum as a positive member of FTE.
Talking 17* pump is finally in!
Finally got her in today. Lookin good for leakage as well. Took some cranking to get her to roll, but she pulls pretty good now. On a side note, I ordered the Sky Manufacturing shackle reversal kit. That's all I need to finish my 4x4 conversion.
I'll keep you posted. I'm also prepping for the IC install. Just need to make some mounts. Gettin the PMS shakes pretty bad now......
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW 3.55 gears ,cat delete, 4" exhaust, SC 1705, Stage 1 DIY sticks, Valair SMF, 203* thermostat, 3" DP, SD intercooler, 17* HPOP, 37/12.50/16.5's and some more stuff
  #2 (permalink)
Old 11-03-2009, 06:02 PM
95_Dually's Avatar
95_Dually 95_Dually is offline
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE. 95_Dually is gaining momentum as a positive member of FTE.
Did you take it for a "test drive" yet?
I hear money, lots of money and time is the best cure your shakes.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v
2000 Ranger 4X4 No MODS, yet!
  #3 (permalink)
Old 11-03-2009, 11:02 PM
jleal_21's Avatar
jleal_21 jleal_21 is offline
2004 Ford F-150
My Garage
jleal_21 is starting off with a positive reputation.
is this swap an easy bolt on or is it more complicated than just takin the old one off and replacing with the new one?
__________________
1996 F250 CC Short Bed 7.3l, auto, 4x4, 3.55, 6637 mod, 6 pos. chip, fpr shim
  #4 (permalink)
Old 11-03-2009, 11:07 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is starting off with a positive reputation.
Good one Dually!
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #5 (permalink)
Old 11-04-2009, 10:21 AM
Rice Rocket Eater
It was a fairly easy swap. It took my son and I most of the morning. It would have been tough without Cody's (Rubberduck) writeup. As for the test run, I hit just over 120 on the gravel and she was still pulling when I backed out. I was surprised that the EGT weren't too bad. Never got over 1100. Maybe after I get the IC and everything set up, I'll take her for a solid 'HOT' run on pavement instead of just playing around.
Dually, as for your cure for the shakes, my wife says, "I don't want to hear that."
__________________
Fullcrew7.3
Dave
  #6 (permalink)
Old 11-04-2009, 10:57 AM
redone1 redone1 is offline
redone1 is starting off with a positive reputation.
120 on gravel!!!!!!
__________________
1997 F-350, 4X4, Standard Cab, Long Bed, 4.10's
DIY 6637, 3" DP, 4" straight exhaust, True-Cool Tranny Cooler, RDS Stage 2's, PHP Chip, Guages: Exhaust-Tranny-Turbo
  #7 (permalink)
Old 11-04-2009, 10:58 AM
oh, just noticed your probably talking KMH not MPH.
__________________
  #8 (permalink)
Old 11-04-2009, 11:16 AM
MagKarl MagKarl is offline
MagKarl is starting off with a positive reputation.
Has anyone ever done the 15 to 17 HPOP upgrade and not been happy with the result? I have a 17 sitting on the shelf waiting for some free time, but there's always a little bit of risk pulling a part that work in favor of an unknown part.
__________________
1995 F350 XLT CC 4WD PSD 5 Speed
2001 Excursion Limited 4x4 V-10
  #9 (permalink)
Old 11-04-2009, 11:20 AM
i've never heard of anyone not liking more oil. What's the history on the 17*? how many miles are on it?
__________________
  #10 (permalink)
Old 11-04-2009, 01:25 PM
Quote:
I went from the 15 to 17 and really didn't notice all that much. The bucking at higher RPM's was not as bad but still there. That was on stock sticks.
__________________
Glenn
  #11 (permalink)
Old 11-04-2009, 01:53 PM
Rice Rocket Eater
Redone1, I pre-converted my numbers for you Southern folk. I did mean 120 mph (200 kph) on gravel. She was really flying!!! Not pulling quite as hard as I had hoped, but I did put in a used 17* as opposed to new or aftermarket. Still considerably better than before.
__________________
Fullcrew7.3
Dave
  #12 (permalink)
Old 11-04-2009, 02:00 PM
Man you have some steel kauhuna's. Did you use a gps as a speedo?
__________________
  #13 (permalink)
Old 11-04-2009, 03:35 PM
Rice Rocket Eater
Nope, just the speedo. I kinda forgot about the GPS. I'll have to dig it out of the boat and try that.
__________________
Fullcrew7.3
Dave
  #14 (permalink)
Old 11-05-2009, 09:20 PM
95_Dually's Avatar
1995 Ford F-350
My wife doesn't like the "cure" for the shakes either.LOL
What speedometer do you have in your truck? Pics please.
__________________
Sam
  #15 (permalink)
Old 11-06-2009, 09:36 AM
yeah let see some pics! My speedo only goes to 85 or 90
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
