Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 05:13 PM
johnnyutah909 johnnyutah909 is offline
johnnyutah909 is starting off with a positive reputation.
lifted 4x4 ranger
what type of affects will a 3-6" suspension lift have on on 03' 4x4 ranger
  #2 (permalink)
Old 11-03-2009, 10:25 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
It makes the effort to get into the cab harder because you have to overcome the force of gravity for a longer period of time.
It increases the distance of the center of gravity of the truck from the ground, this might be important if you are doing high speed evasive manuvers, might be important if you're doing low speed crawls at a high angle from the plane of your tire-ground interface points. I suggest a dynamic analysis be conducted by an experienced engineer before conducting such operations. Oh, wait, Ford did that already before they decided not to put lifts kits on their trucks.
Nevermind.
  #3 (permalink)
Old 11-04-2009, 07:07 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE. wendell borror has a great reputation on FTE.
Lift kits for the newer t-bar suspension rangers are quite expensive. I've only have seen them offered from superlift and dixon brothers in a 4" lift. The superlift starts at around 1,500$ and DB at 3 grand
__________________
2009 FORD RANGER fx4 off/road, 5-speed manual, torson diff and rancho's!
2008 mercury mariner 4x4 V-6, automatic.
1987 jeep wrangler, 258, 5-speed
  #4 (permalink)
Old 11-04-2009, 09:51 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
I love the lift on my '04, but as Wendell noted, it wasn't cheap. Since the Superlift uses the stock springs, the ride is basically unchanged, excepting the stiffer shocks.
The C.G. is higher, as g_k50 noted, and if you install taller tires, you may not like the taller gearing unless you re-gear. Also, the taller tires will reduce the braking strength, so be careful not to go too tall. I have 32" tires and wouldn't recommend anything higher. The costs just keep adding up...
__________________
2004 Ranger FX4 Level II, Superlift 4" lift, Bama program, BFG 32x11.50x15 tires, Undercover, Rancho RS9000X shocks.
  #5 (permalink)
Old 11-04-2009, 11:46 PM
R031Kona's Avatar
R031Kona R031Kona is offline
R031Kona is gaining momentum as a positive member of FTE.
My 5.5" lift and 33's make it hard for a old guy to drag his fat a$$ into the truck!!
__________________
91 Ranger XLT SCcab 4.0L 5 Spd, 51/2" lift, Flowmaster , Winch, 33"Baja MTZ's, Belltech Shackles
BC Chapter Member
  #6 (permalink)
Old 11-05-2009, 10:55 PM
Yes, that first step is pretty high if your legs aren't long! After I installed my lift, I also installed a "nerf bar" step for the benefit of my short girlfriend. Turns out, I use it a lot. It's more useful than I anticipated and the grab handle in the cab helps, too
__________________
  #7 (permalink)
Old 11-05-2009, 11:08 PM
Damonkr's Avatar
Damonkr Damonkr is offline
Damonkr is starting off with a positive reputation.
I have an 02 ranger with 7" of lift (4" suspension, 3" body) with 35" tires.
I would not recomend that much lift. I wish I would had stuck with 4" and 33" tires.
The extra height of the 35" tire puts alot more stress on the small and expensive unit bearings. I have also gone through upper and lower ball joints a few times in the last 70,000 miles.
However it drives great when things are in working order. I installed 4.88 gears and they gives my 4.0 some power back.
Also it looks good too...that must count for something
And it loves the snow.
Hope this helps you with your decision.
  #8 (permalink)
Old 11-06-2009, 05:33 PM
Looks good my man!!!!! I'm not a big fan of body lifts, but it looks good on your truck. I'm even to tight to buy an expensive lift kit. I just cranked the T-bars to level it and threw on some 32"X10.50's. That still allows me to drag my fat butt into it ha ha.
__________________
  #9 (permalink)
Old 11-07-2009, 12:06 AM
Yeah, it does look good! But at 5'6", the door sill probably comes up to my waist! I don't think I'm spry enough to hop up that high. I always wondered how those guys with lifted F250s managed it...
__________________
  #10 (permalink)
Old 11-07-2009, 11:26 AM
Damonkr's Avatar
My wife is 5'nothin and she drives it all the time. she just hop right in. It's wether you want something that big. Like I said in my earlier post I would stick with a 4" lift and 33" tires there is one running around localy and it looks good and probably doesn't go through parts as bad as mine. Also keep your wheel offset as close to stock as possible. I think my 12" wide weld wheels eat unit bearings for breakfast, lunch, and dinner.
  #11 (permalink)
Old 11-07-2009, 01:53 PM
Of course taller lifts and larger, heavier tires will use more fuel. Also larger tires will require a gear swap to keep the engine in it's normal power band performance wise.
__________________
Tags
4x4 , ford , forum , lifted , mazda , ranger , rangers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
