You can test your pumps by grounding a wire in your test plug, its over by your air box attached to the fender, it has 4 leads, only one has 2 wires in it, there both green wires, take a wire to your ground terminal on battery or anywhere really(on truck lol) an ground it to those 2 green wires an with the ignition on your pump should come on. All that does is engage the fuel pump relay. Hope that was helpful.
