Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 01:10 PM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
5.0 MAF conversion questions.
hey guys. i'm new to these EFI gas burners, but i'm building a 5.0 right now to replace the 4.9L that was in my 1994 F150. the 5.0 is from a '92 f150. so far i have the engine torn down but it's going back together this week so i gotta get the MAF ready and all the wiring so i can get the engine started up. what all do i need to do??? the truck i'm putting the 5.0 in was a 4.9 so it still has all the 4.9 wiring harness and computer in it, but i have the complete 5.0 harness from the same '92 i took the engine from and the computer as well. does that make any sense? haha.
The engine has 9.08:1 flat top pistons, gt40p heads, E303 cam, and typhoon upper and lower intake. im going to go ahead and put 24lb injectors in it while everything is apart and i also have a smog pump eliminator also. So i saw on summit that they have the MAF sensors for different injector flow rates and everything and probably end up getting one of theirs, but if anyone could tell me what else i need to do to the MAF conversion and perhaps tell me what i need to do to hook it all up i would greatly appreciate it.
Thanks
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #2 (permalink)
Old 11-03-2009, 01:33 PM
subford's Avatar
subford subford is online now
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
You need a different computer. The one you have is for the MAP sensor.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 11-03-2009, 01:36 PM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE. Lazy K is gaining momentum as a positive member of FTE.
http://www.ford-trucks.com/forums/88...onversion.html Do a search and you will find more threads like this one with some good links.
  #4 (permalink)
Old 11-03-2009, 01:42 PM
SparkyShaft SparkyShaft is offline
SparkyShaft is starting off with a positive reputation.
You will need a radiator for V-8. 6 Cylin. is different. You will need the computer an MAF sensor from V-8 donor truck. Also you will have to remove the brackets that the motor mounts attached to on your 6cyl. On crossmember. And then you will need the brackets outta a V-8 truck to bolt in directly behind the crossmember. Also make sure the truck your harness is from is for a MAF truck an not a speed density because the injectors are wired differently between a speed density an a MAF.
  #5 (permalink)
Old 11-03-2009, 02:00 PM
lew52's Avatar
lew52 lew52 is online now
lew52 is gaining momentum as a positive member of FTE.
Is it a stick or auto ?? If its a stick you can use the computer from a 5.0 mustang , if its a electronic controlled auto you will need the computer out of a mass air auto truck & all the harnesses ... Lew
  #6 (permalink)
Old 11-03-2009, 02:06 PM
ok i will clear some things up here. haha
the truck i got was/is a '94 single cab short bed 4x4 5 speed. i pull the 4.9 out of it and putting the 5.0 in so i bought a complete donor truck that had been rolled that had a 5 speed and 5.0. so i got the radiator, engine stands that bolt to the crossmember, everything except the correct computer system to run the MAF.
Lew, with all this said you say i can run the stang computer. which stang computer and does the stang computer require any different injector wiring to hook up the MAF? i was reading somewhere someone switched to like HO or whatever and was having to change out the injector wiring for whatever reason. i will read that link now. hopefully its relatively easy to hook up the MAF!!! haha. thanks guys. i appreciate this. i can do everything to this truck but when it comes to this swapping to MAF i'm like WAYYY over my head so far and i'm confused. hopefully y'all clear up my confusion. LoL
__________________
  #7 (permalink)
Old 11-03-2009, 02:18 PM
lew52's Avatar
Your using the E 303 roller cam so the firing order is the same as the HO ,. It should work fine with the upgraded mass air meter , most aftermarket meters are set for the mustang , but you may need a custom tune after ?? ....Lew
  #8 (permalink)
Old 11-03-2009, 02:46 PM
lew52's Avatar
I would really check everthing out first & see what is the best way to do this . Theres going to be alot of wiring either way , the HO is ob 2 & your 92 is ob 1 but not MA , You could also get the comp & harness out of a 95 mass air truck thats ob 1 , might be easyer ???? ... Lew
  #9 (permalink)
Old 11-03-2009, 02:50 PM
As long as the harness came outta the with MAF already then the injectors will be wired correctly. And as far the wiring for the MAF meter, the wires for it are over near the air box. Should be able to see it comparing the 2 trucks harness.
  #10 (permalink)
Old 11-03-2009, 04:12 PM
If i get the '95 harness, computer, and the MAF would the injector wiring be the same as mine or would i have to change the injector wiring?? i'm so confused right now its not even funny expecially after reading the stuff in that link. guess i don't know enough about these little trucks yet.. haha
__________________
  #11 (permalink)
Old 11-03-2009, 04:23 PM
subford's Avatar
The injector wire in a 95 5.0 is SFI.
__________________
subford@gmail.com
  #12 (permalink)
Old 11-03-2009, 04:29 PM
ok so pre '95 they were bank and then '95 and up were sequential.. got ya. now, what would i have to do to wire up the sequential? or would i just get a '95 harness with the injector wiring already done sequential with the factory MAF and computer. would all that directly swap over or would i need to do some major surgery? if it will swap i will call some JYs around here and look for a '95 computer and harness.
Also what would the difference be if i was to use a stang computer in the way i would wire it all up? use stang computer and maybe the '95 harness????
__________________
  #13 (permalink)
Old 11-03-2009, 04:31 PM
lew52's Avatar
Yes the 95 harness & computer will be SFI & mass air with the 351 302 HO firing order . I have a 302 HO in my 95 with the e 303 cam & it was a direct swap . The 95 trucks are mass air roller cam motors with obd 1 computer...
  #14 (permalink)
Old 11-03-2009, 04:38 PM
subford's Avatar
No, 94 5.0 and up were sequential.
__________________
subford@gmail.com
  #15 (permalink)
Old 11-03-2009, 04:41 PM
ok cool. my engine was factory roller cam non MAF OBD1 and didn't have SFI. i am learning more and more here. so my E303 will work with my engine. i just gotta get a '95 harness which is the HO firing order and put the '95 harness on here. so would i have to rewire the '95 harness at all??? it doesnt sound like i would have to do too much to it
im very sorry if i'm being a pain in the a$$, but i literally jumped on this project NEVER having worked with these EFI gassers before. haha. probably shouldn't have jumped into it, but i'm there now so i gotta get it done so the engine will run. haha
__________________
Tags
50 , 87 , air , conversion , density , f150 , flow , ford , maf , map , mass , mustang , package , sensor , speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
