Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-03-2009, 05:01 PM
lew52's Avatar
lew52 lew52 is offline
lew52 is gaining momentum as a positive member of FTE.
I think your OK ,,, The distributor has to have a steel gear on it for the E 303 cam , but if the dist came out of a roller motor it will have a steel gear .... Lew
  #17 (permalink)
Old 11-03-2009, 05:40 PM
SparkyShaft SparkyShaft is offline
SparkyShaft is starting off with a positive reputation.
Ford Fuel Injection Wiring Harnesses check that out it will tell you everything you need to know about the computer differences has charts an the fuel injection difference firin order an everything. Pretty simple. I had to rewire mine because I had a 94 bronco harness outta a HO motor, it was sequential, and I didnt have the computer for it, I was usin an older comp. and motor outta an 88' that was bank firing to get proper fuel with older computer.If you use the 95 harness, an computer, it will work. You only have to rewire it if you try to use an older computer and motor . 94 to 96 has the SFI
  #18 (permalink)
Old 11-03-2009, 06:24 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE.
Not all 94 and 95 trucks were mass air, and only the ones with mass air were SFI. The wiring pinout might be different between the mustang MAF computer and truck MAF computer as well. Just keep that in mind when looking for parts.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #19 (permalink)
Old 11-04-2009, 12:19 AM
strokin'_tatsch strokin'_tatsch is online now
strokin'_tatsch is starting off with a positive reputation.
ok well i didn't have time to dig in the junkyards today, but tomorrow i will call around and try to find a '95 computer, harness, and MAF. hopefully with all that i can just put it all in the truck and have it work correctly.. am i right with this? i think i am... haha. i will read through that link tomorrow. thank y'all for the input so far!! hopefully we can get this thing up and running this weekend!! i'm getting excited this truck hasn't been driven in the last 2 years so i'm sure its looking forward to driving again! that is after i change all the fluids and everything.
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #20 (permalink)
Old 11-05-2009, 01:18 PM
hey guys. i was really confused on the MAF, but upon more research im starting to figure it out i think. if i get stang computer A9L which is sequential MAF, of course the MAF sensor(going summit probably 73mm).. do i need to install another O2 sensor using this computer? i'm not sure which year model A9L was from either, but i know its a stang mass air computer. haha.
Does anyone know where i could find an overlay harness so i can use my harness and then use the over lay harness to wire in the injectors and MAF meter? or should i forget that and use a '95 F150 harness with the F150 computer or should i use the A9L? is there an advantage to using the stang or F150 computer? the whole reason i'm confused is simply because there are so many people that did this conversion so many different ways that i don't know which way would be the best way to do this. i am now up to using the B303 cam b/c the place i bought the E303 couldn't have it to me in time so they sent the B303. LoL.
Thank y'all so much for y'alls help. if y'all could let me know if i should get an overlay harness and possibly point me in the direction of one or if i should get the F150 harness that would be great. i'm learning a lot about this truck so far!!!
__________________
  #21 (permalink)
Old 11-05-2009, 06:02 PM
lew52's Avatar
With the mustang computer it will need two 02 sensors , Also the rev limiter is set alot higher than the truck computer . Both will be sequential if its from a MA truck . Check out pro m racing , they have all the harnesses & meters for the conversion .... Lew
  #22 (permalink)
Old 11-05-2009, 11:01 PM
Lew, thank you for that. that was helpful!! i pretty much suck at reading wiring diagrams unless its VERY straight forward and the ones i been looking at arent that straight forward. LoL. so that helps a lot. is it better to have 2 O2 sensors?? i'm going to have to get a bung and put it in for the one anyways b/c i'm getting ALL new exhaust from the headers back. i would assume 2 is better b/c it can read more accurately using both sides. i will check out Pro M. i just want to make this as SIMPLE as possible b/c while i can wire in some pretty good stereo systems and what not this is totally different. haha. Do you think this would be the most simple route or the '95 harness?? THANK YOU SOOOO MUCH!!!
__________________
Tags
50 , 87 , air , conversion , density , f150 , flow , ford , maf , map , mass , mustang , package , sensor , speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
