Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 11:56 AM
ytr1903 ytr1903 is offline
ytr1903 is starting off with a positive reputation.
Front hub assembly
I have a 2000 F-150 4x4 with disc brakes on all wheels. My driver's side wheel bearing assembly has gone bad and I am trying to replace it. I have removed the caliper and the three bolts on the back of the hub. I have also removed the large 35mm nut mounted on the shaft. Here is the problem, I have applied "judicious" use of a large hammer on the back of the hub, but have not been able to jar it loose. Am I missing something here? Or should I get more serious about beating the daylights out of it?
Thanks is advance for any help,
Tom
  #2 (permalink)
Old 11-03-2009, 09:27 PM
papajoemrt's Avatar
papajoemrt papajoemrt is offline
papajoemrt is starting off with a positive reputation.
this might be dumb but have you removed the cv shaft from the bearing assembly? might help i don't know. I took my whole front end apart on one side doing ball joints, why i don't know, but it came out easier that i thought actually. try spraying some aero-kroil or pb blaster if you have some
__________________
2002 F-150 Screw
Kenwood DDX512, Pioneer Doors, Image Dynamic Subs
Dumped Flowmaster Super 40
Trans-Go Shift Kit
Gotts Intake Mod
  #3 (permalink)
Old 11-03-2009, 10:30 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
after loosening the 35 mm nut, the shaft should push inward 1 inch toward the motor. that shows you the splines are not stuck. if it wont push, tap on it a little, if its stuck, you need to bolt a pusher plate over the studs and use the center jack screw to push the half shaft inward. once it is loose, your right, the hub just pops out. you may have to use a pointed chisle to drive between teh knuckle and the hub to get a gap. normally hitting the hub a few times will start it moving. good time to check lower ball joint also.
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 190,000 miles
2002 Explorer 4 x 4 4.0 XLT - 120,000 miles
  #4 (permalink)
Old 11-04-2009, 06:23 AM
Thanks, guys. The shaft floats in the hub, so I don't think that is part of the problem. I will now apply the pointed chisel method and see how that works.
Tom
  #5 (permalink)
Old 11-04-2009, 09:17 PM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
I've found that PB Blaster, a wood block, plus a BFH on the side of the flange is also needed at times.
If you are replacing it, I wouldn't be afraid to wail on in as long as you are using a wood block.
Becareful of where you hit, and don't miss!
__________________
'01 F150 5.4L 4x4
  #6 (permalink)
Old 11-04-2009, 09:25 PM
DLP Performance DLP Performance is offline
DLP Performance is starting off with a positive reputation.
Knock the crap out of it!!!! Hit it from various directions, not just in one spot. Be generous with the penetrant!
  #7 (permalink)
Old 11-17-2009, 08:53 PM
fordf150farmer's Avatar
fordf150farmer fordf150farmer is offline
fordf150farmer is starting off with a positive reputation.
haha heres a question for ya. when does a hamer get to big? .... when you cant pick it up. when the bfh fails, go for the RBFH. also an air chisel (sp) isnt a bad idea. use it like the chisel and hammer. it may not seem like it but man that vibration can work some ***** lose.
Tags
4x4 , 97 , assembly , f150 , ford , front , hub , motor , replacing , truck , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
