Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-06-2009, 10:33 PM
1whoseeks 1whoseeks is offline
1whoseeks is starting off with a positive reputation.
fyi-- check local laws reguarding headlights
Since in the early 1990s, HID lamps have been employed in motor vehicle headlamps. This application has met with mixed responses from motorists, who appreciate the improved nighttime visibility from HID headlamps but object to the glare they can cause. HID colors approach the same color as sun light. Internationalized European vehicle regs require such headlamps to be equipped with lens cleaners and an automatic self-leveling system to keep the beams aimed correctly regardless of vehicle load and attitude, but no such devices are required in North America, where inherently more glaring beam patterns are also permitted. Retrofitting HID bulbs in headlamps not originally designed to accept them results in extremely high levels of glare, and is illegal throughout most of the world.
http://dsl.torque.net/images/techdoc..._Crackdown.jpg
Daniel Stern Lighting Consultancy and Supply
  #17 (permalink)
Old 11-18-2009, 05:52 PM
Araltd Araltd is offline
Araltd is starting off with a positive reputation.
Just thought I'd finalize my input to this thread...
I ended up with the 6000k Diamond white HID headlights and fog lights. They look amazing. The 6000k ARE the one's I wanted - white with just a hint of blue... ANY MORE BLUE AND I WOULD HAVE BEEN EXTREMELY DISAPPOINTED!
Many thanks to all who posted. I love my HID's! Might be the best $100 I spent on this truck so far.
  #18 (permalink)
Unread Yesterday, 01:28 AM
fiveohpoepoe's Avatar
fiveohpoepoe fiveohpoepoe is offline
fiveohpoepoe is starting off with a positive reputation.
Send me the details and pics if you would please. Im thinking about going this route but I really want all white. Im know squat in this area...Thanks
fiveohpoepoe@gmail.com
__________________
Boys In Blue Have Fun Too
99 Lifted/04 Expeditions
  #19 (permalink)
Unread Yesterday, 06:24 PM
From what I understand, the 5000k are pure white - with no blue. And also at 5000k you get the maximum light output - though I can't back that up.
installation is not quite as plug-n-play as advertised - at least in my expedition, there just simply wasnt space given the amount of wire available, so we had to remove the grill and headlights, using screws and ultimately zip-ties, we had to mount the 4 ballasts, 2 on each side, 1 on top of the other, using screws into the sheet metal, the included METAL brackets and a couple zip ties to hold them all together. Then putting everything back together - it took around 3+ hours give or take... Remember, I also did my fog lamps as well, and if you have fog lamps I highly recommend doing them the same color - the look is very nice and factory looking.
So, the kits I bought from a local dealer cost me $55 each, they are the larger ballast - and the ballasts are digital - what that actually translates into - I'm not sure....
The headlights are HID LOW and HALOGEN HIGH... and the HALOGEN HIGH are much dimmer than the HID LOW The fog lights are HID only, and they needed to be trimmed just a bit in order to fit properly, but it was pretty simple with a hand held grinder (dremmel) I'm sure that varies from chinese manufacture to chinese manufacture
Here's the front of the truck with the headlights out, and grill out - this was to give us enough room to mount the ballasts behind the grill (well, really behind the bumper) under the headlights... We screwed the ballast bracket into the metal.
HID LOW's ON (test)
HALOGEN HIGH'S ON (test)
(the picture's don't do it justice... It need to see them in person to appreciate the color, and brightness)
Here's the finished deal in my driveway
Tags
150 , fog , ford , headlights , issues , kit , light , lightning , lights , truck , trucks , xenon , xeon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
