Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 08:22 AM
48fordf1 48fordf1 is offline
48fordf1 is starting off with a positive reputation.
YET ANOTHER AIR RIDE PROBLEM
I RECENTLY BOUGHT A 99 EXPY WITH A BLOWN MOTOR AND THE REAR WAS SAGGING BUT I HEARD THE PUMP RUN SO I WAS NOT WORRIED. NOW THE NEW MOTOR IS IN AND THE REAR STILL WILL NOT RAISE. THE COMPRESSOR WILL CYCLE A FEW TIMES AND THEN THE CHECK SUSPENSION LIGHT WILL COME ON. THE CODES ARE C1845 AND C1869. FRONT GATE SOLENOID AND FRONT INFLAMER CIRCUIT. THE REAR DOES NOT EVEN START TO RAISE AT ALL BUT I HERE THE SOLENOIDS CLICKING BUT CANNOT HEAR ANY LEAKS. I VISUALLY INSPECTED ALL THE COMPONENTS AND ALL LOOKED GOOD. THE COMPRESSOR DOES SOUND LIKE ITS READY TO DIE BUT IT STILL WORKS. IS IT POSSIBLE FOR THE COMPRESSOR TO NOT PUT OUT ENOUGH AIR BECAUSE IT IS SO WEAK? THE FRONT IS FINE. THANK YOU IN ADVANCE.
MATT
  #2 (permalink)
Old 11-03-2009, 04:15 PM
Omahastro1 Omahastro1 is offline
Omahastro1 is starting off with a positive reputation.
Maybe you already checked this out but over by the master cylinder there is a union in the air line that feeds the rear. This union is known to break.
  #3 (permalink)
Old 11-03-2009, 06:05 PM
eallanboggs eallanboggs is offline
eallanboggs is starting off with a positive reputation.
Soap and water in a spray bottle.
  #4 (permalink)
Old 11-03-2009, 07:44 PM
tried soap and water and found no leaks. so i started playing around, i removed the pump and the drier and turned it on and it was definately pumping air out. so i put the drier back on let it pump for a while then removed the drier and it had tons of air pressure behind it. so now i am wondering if it could be the solenoids on the bags themselves or what is the inline solenoid looking thing on the drivers side frame rail that the rear air line passes through? thanks, matt
  #5 (permalink)
Old 11-03-2009, 09:31 PM
ok played some more and i think it is the pump. getting air pressure all the way to the bags but it doesnt seem like much. if i jack up the rear a little and take some pressure off the bags and run the pump, i got the bags to take and hold air. if i put my finger over any line while the pump was running it would not even blow around my finger. what do you guys think?
  #6 (permalink)
Old 11-03-2009, 09:34 PM
American Air-1's Avatar
American Air-1 American Air-1 is offline
American Air-1 is starting off with a positive reputation.
Matt, keep in mind that even though the compressor is making pressure, it may not be enough to raise the rearend. per the Ford shop manual, it has to be able to build 120 psi minimum. Why don't you give me a call tomorrow and we'll figure out whats going on.(423-487-4321)
__________________
EDDIE-2000 F350SD, 7.3 PSD, AT, LWB CC, centurion conv., Bully-Dog 5 inch exhaust, DP Tuner, DieselSite ext. tranny filter, Mickey Thompson radials, leather seats, DVD player, 6in. susp. lift, foil delete mod, daytime h/l delete mod, K&N air filter, Mag-Hytec rear cover, white face cluster w/flames, frt. chrome brushguard w/KC lights.
  #7 (permalink)
Old 11-03-2009, 10:16 PM
ronjeremy6's Avatar
ronjeremy6 ronjeremy6 is offline
ronjeremy6 is starting off with a positive reputation.
423? you may be my saving grace. i'm over here in north alabama and my 99 will deflate 40-50 seconds after exit. i read its supposed to be more like 45 minutes. i'll be giving you a call soon if that's ok.
  #8 (permalink)
Old 11-09-2009, 04:10 PM
themooser themooser is offline
themooser is starting off with a positive reputation.
Have had alot of issues with my air suspension over the years and finally got tired of it and recently had a spring conversion done - best move I ever made and it only put me back @ $300 (parts only - my mechanic hooked me up on labor).
The first problem was a broken union in the line running back to the bags. Found the part online ($20 with shipping) and took me all of 10 minutes to install. That worked for about a year or two then noticed that the compressor was coming on more than usual. After driving about 30 min or so, the compressor would kick on and do its thing to inflate. Turns out it was the bags themselves. Try checking those - mine had small cracks in them (which they will develop over time) and could never maintain pressure. Was too expensive to replace bags so I converted to springs. Rides just as smooth.
Tags
1997 , 2006 , air , expedition , ford , lincoln , line , problems , raise , rear , ride , sagging , truck , union , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
