Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 06:48 AM
SlickWiSlick's Avatar
SlickWiSlick SlickWiSlick is offline
SlickWiSlick is starting off with a positive reputation.
mist from the defroster
I was driving my 1965 F100 the other day and in the cool weather the windshield began to fog up. I've got the basic heater/defroster. I slid the lever to defrost and turned the knob for the blower. The cab filled with a greyish haze. Probably lots of dust, but it looked smokey, but didn't smell smokey. Obviously I shut the blower and defroster back down and rolled down the windows.
Later on I noticed occaissional pillars of whitish mist wafting out of the defroster vents in the dash. These were very faint and at first I thought they were shodows from outside on moving across the windshield.
Anyone ever see this before? I'm concerned that I might have a small leak in the heater core. I did not smell coolant or anything else while observing the mist.
  #2 (permalink)
Old 11-03-2009, 08:41 AM
instig8r63's Avatar
instig8r63 instig8r63 is offline
instig8r63 is starting off with a positive reputation.
Your heater core is seeping.
__________________
Bobby
1972 F100 Short Bed
1963 Uni Longbed 390/C6
1967 Mustang Fastback 390 4-speed
  #3 (permalink)
Old 11-03-2009, 08:45 AM
BarnieTrk BarnieTrk is offline
BarnieTrk is starting off with a positive reputation.
Unfortunately, I think you're on the right road, a heater core leak would be my first suspicion too. I'd check your coolant level and see if the level is down. Run an errand with the truck to bring the coolant up to operating temperature. When back home, with a wheel blocked and the engine running, up look under your dash near the heater for any dripping or wet spots, try to repeat and observe the misting condition again. I wouldn't want to ignore this & not find the cause and remedy the situation....
Good Luck & keep us all posted with your progress!
BarnieTrk
__________________
- 2WD '65 F100 short box, 390" FE, T-18 4spd
- 2WD '65 F250 long box, 390" FE, T170FT 4spd OD
- 2WD '94 Ranger XLT, r/cab, 139" (2.3L) 4-cyl, 5spd
  #4 (permalink)
Old 11-03-2009, 09:09 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Ditto to what Instigator and Barnie said.
The heater core is leaking into the plenum chamber (heater box).
When this occurs, the windshield fogs up.
Usually...the toe board and the floor below the plenum chamber will be damp.
__________________
Bill / Retired Ford Partsman (1962/97) / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Passenger Cars: 1928/89.
  #5 (permalink)
Old 11-03-2009, 09:48 AM
Thank you, Gentlemen, for the investigative procedure. The manual is silent on this. I searched the forum for similar posts and found nothing, but it does sound as though there are replacement cores for not a lot of $ for the '65 and ups. I should probably start looking for one.
  #6 (permalink)
Old 11-03-2009, 10:16 AM
SWS,
If you determine that the moisture is coming from a cracked or leaking heater core, it will resulting in you draining the coolant system and replacing or repairing it. If you do end up draining the system and pulling the heater core, I'd also plan to replace the heater hoses and clamps with new ones and give a serious eye to the radiator hoses and the condition of the radiator.
Depending on how long it's been since any cooling system work has been done, it might be a good time to go ahead and pull the radiator out and have it pressure-tested while the system is down & drained. I'd also wiggle on the fan a bit looking for any play in the water pump bushing/seal.
I usually don't like having too many things torn apart, but in this case, they aren't that big of a deal nor expensive - and once all the 'wear-able' parts have been inspected and/or replaced, fresh & new coolant mix - you'll be ready to feel the heat again without the humidifier effect!
BarnieTrk
__________________
  #7 (permalink)
Old 11-03-2009, 05:15 PM
Thanks for the advice on redoing the hoses, etc. I just checked for play in the fan last weekend...probably messed up the heater core (kidding). It seemed okay.
I took the truck up to my polling place, it being election day, and noticed a small trickle of coolant on my floor mat. Windshield steamed up but is was warmer out, so not as pronounced.
I couldn't find a new heater core on the NAPA site. Autozone has one for $19, $25.76 delivered. Rock Auto has one, but lists it as starting in 1966, not 1965. It costs 40% more, too. I thought I'd read here that the same core was used 1965-1979. I'll search some more. Looking for a reason to avoid the Autozone, maybe I'm just paranoid.
  #8 (permalink)
Old 11-03-2009, 05:42 PM
Ford Parts Guru
Quote:
That may be true for autoparts store universal aka fitz all heater cores.
It is not true with Genuine Ford Parts, as you can see...
C5TZ18476B .. Fresh Air Heater Core / Fits: 1965/66 F100/250.
C7TZ18476A .. Heater Core / Fits: 1967/72 F100/750 w/o factory installed integral A/C.
C8TZ18476A .. Heater Core / Fits: 1968/72 F100/350 w/factory installed integral A/C.
C6OZ18476B .. Heater Core / Fits: 1973/79 F100/350 with high output heater.
E3TZ18476B .. Heater Core / Fits: 1973/79 F100/350 with Economy heater.
E3TZ18476C .. Heater Core / Fits: 1973/79 F100/350 with factory installed integral A/C or with High/Low Comfort Zone Vent System.
Now...what were you saying about all 1965/79 heater cores being the same?
__________________
  #9 (permalink)
Old 11-03-2009, 07:10 PM
Thanks Bill.
  #10 (permalink)
Old 11-03-2009, 10:55 PM
mkoser's Avatar
mkoser mkoser is offline
mkoser is starting off with a positive reputation.
Depending on how exactly you want to do it, sometimes other heater cores will work ok...
When I was a poor college student, the heater core let go on my 64 Pontiac.
I went to the parts store to order a new one. It was something like 250 bucks 10 years ago. The clerk then said, "hold on a second."
He came back up to the desk with 5 or 6 different ones and we looked and compared each one (to the old one that I already took out).
We were able to find one that was nearly identical, except the inlet was about 1/4 of an inch higher on the new one. I had the room to work, so it wasn't a huge deal.
The replacement was for a mid 80's buick... Out the door was $21.67. I just looked a the receipt the other day (I still have the car with that Buick heater core....)
Sometime it pays to see what your options are...
MK
  #11 (permalink)
Old 11-04-2009, 12:08 PM
If I were able to find a donor in a yard with the fresh air (deluxe) heater system in it, how practical would it be to replace the standard heater system?
Anyone ever do this upgrade? I understand the risk in buying a core from a years old wreck, but if I've got to have a shop modify one to fit properly, I might as well add some value if possible.
  #12 (permalink)
Old 11-04-2009, 12:53 PM
airharley's Avatar
airharley airharley is offline
airharley is gaining momentum as a positive member of FTE.
There was one on evilbay a week ago with the fresh air package (C1TZ 18A594-A) for $25... I know someone is a happy person that bought it. The guy was chopping 1963 truck for parts and didn't want to trash it. Unfortunately I do not have his email anymore in my messages.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
Author of the disc brake article for 57-64 F-100's
  #13 (permalink)
Old 11-04-2009, 04:25 PM
Ford Parts Guru
Someone is not a happy person if he/she bought it for a 1965/66, because...
A heater from a 1961/64 F100/1100 (which is the same) will not fit a 1965/66 F100/250 (because it is not the same!).
The heater water valve or shut-off valve is the same, the 5/8" heater hoses are the same, what else is?
Nada, nothing, zero, zilch. For example:
C1TZ18A594A .. Connector, Heater Air Inlet.
Fits: 1961/64 F100/1100 // 1961/69 N/NT/T500/1000.
Take a look-see in our parts catalog, kiddo: Illustration Section 184, Page 9. Does that heater look like the one in your 1964?
It doesn't....cuz it ain't.
__________________
  #14 (permalink)
Old 11-04-2009, 04:31 PM
airharley's Avatar
LOL Thank god only the 65/66's are the red headed step children of the 61-64 trucks. I believe the guy added the info I sent to him letting him know they didn't fit on anything past 64.
__________________
Mark J. Covill
  #15 (permalink)
Old 11-04-2009, 04:42 PM
Ford Parts Guru
If someone believes ONE word of what an ebay seller sez, they need to take a course in Reality 101.
These ppl are clueless...and if they're selling obsolete parts, it's even worse.
They look at the part number's prefix, assume it fits F100's. Mebbe it does, mebbe it does not.
The same prefix was used on ALL F100/1100's, B/C/N/NT/P/T/W500/1000's, and Bronco's.
Some cluck had a NOS C6TZ18813A antenna on ebay recently, said it fits 1961/66 F100's.
Uh huh. It fits 1966's all right, 1966 Bronco's, and 1967/77 Bronco's....PERIOD!
__________________
Tags
150 , 1967 , 2003 , 2wd , box , defrost , f100 , f150 , fogs , ford , forums , heat , heater , mist , ranger , shortbox , truck , turned , vent , windshield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
