Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 04:19 AM
gp's Avatar
gp gp is offline
gp is starting off with a positive reputation.
1971 300 EFI. VERY bad economy & disc conversion??
I have a 1971 F100 I've owned for 31 years. In 1998 I transplanted a 4.9L EFI 6 cyl engine and C6 into the old girl. The initial fuel economy was sensational - 23 mpg and needless to say I was thrilled. After a short period of time the milage became much worse and now has deteriorated to less than 9 mpg!!!
The input resistances are all within range and I've kept the ECT sensor clean. I don't drive this old thing much [certainly much less than 2000 miles per year], but I plan to use it more often in the new year. Any suggestions apart from changing the computer [which may be my next move]??
On another matter - I fitted a brake booster and the improvement to the old drum brakes is wonderful. However; I'd like to convert to a disc brake front end. What's the most straight forward swap over?
G.P.
__________________
1971 300 EFI F-100
1963 F-100
1977 Z1000 Kawasaki
1954 Wife
3 Daughters from the '70s
  #2 (permalink)
Old 11-03-2009, 10:09 AM
bmuhlbach bmuhlbach is offline
bmuhlbach is starting off with a positive reputation.
Get the front end and the proportioning valve from a newer truck 79 is the last year that will bolt in.Could go Power steering also if you don't have it now.
__________________
Buy American your job depends on it.
  #3 (permalink)
Old 11-03-2009, 10:14 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
With EFI pulling the codes should always be the first step.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #4 (permalink)
Old 11-03-2009, 09:05 PM
DLP Performance DLP Performance is offline
DLP Performance is starting off with a positive reputation.
Make sure your new brake booster isn't leaking.
  #5 (permalink)
Old 11-04-2009, 02:11 AM
jhooch's Avatar
jhooch jhooch is offline
jhooch is starting off with a positive reputation.
Make sure you use the proper disc/drum master cylinder also. Just take I-beams, lines and all from a 73-79 F100/150.
__________________
Jhooch
'05 Excursion LTD 4X4 6.0, '01 F250 4X4 Crew 7.3
'73 Bronco 302 C4, '76 F250 4X4 Crew 360, 4-sp
'66 F100 4X2 LB Custom Cab 428, C6
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'63-64 Ford Galaxie's, 55 Ford Customline 2-dr
  #6 (permalink)
Old 11-04-2009, 02:40 PM
As far as a disc- swap, the easiest way is to find a truck at the junkyard around the same year as yours. The tierod ends are a little different on the later models. You can take the kingpins out & swap the whole spindle assembly to your truck. Of course you'll need the afore-mentioned proportioning valve & master cylinder for disc brakes. The brake hoses are different, too. I would replace the calipers, hoses, master cylinder w/ new parts to be safe.
  #7 (permalink)
Old 11-04-2009, 07:24 PM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
lol i like how u put 1954 wife under all the vehicles in your sig.
__________________
1969 F100 RANGER 360 C6
  #8 (permalink)
Old 11-04-2009, 09:44 PM
Holy crap, your steering wheel's on the wrong side!!! That's an interesting grille. Is that Aussie original?
  #9 (permalink)
Old 11-04-2009, 10:56 PM
jhooch's Avatar
If you take the whole thing, I beams and all, you can simply take the steering linkage out of the later truck too. Heck, the last one I did, 77 into a 71, I didn't even have to align it, I set it up and it was perfect.
__________________
Jhooch
  #10 (permalink)
Old 11-07-2009, 02:49 AM
gp's Avatar
gp gp is offline
Yeah, the steering wheel will look odd to you but I cope. I made the grille in a rush one day because a very inconsiderate bird kamakazied into me and smashed one insert. I'm looking for a replacement, but they are as scarse as hens teeth. Do you know where I can find a good grille insert? (I'll need to find the remaining piece to determine which one is missing). I need to put some time into this poor old truck but I've been spending all my spare time restoring my '77 Kawasaki. I really need to rectify the poor fuel consumption so I can afford to leave town without a huge credit card or filling up the back with gold bullion!.
__________________
1971 300 EFI F-100
1963 F-100
1977 Z1000 Kawasaki
1954 Wife
  #11 (permalink)
Old 11-07-2009, 11:05 AM
orich's Avatar
orich orich is offline
orich is starting off with a positive reputation.
I see a lot of trucks with these motors in the junk yards with the head pulled off that have valve troubles. So I would first Read the spark plugs then check the compression.Do a good tuneup. Plug wires may look good and may6be bad so Check wires with an ohm meter is thte best way..
orich
__________________
1971 F250 4x4 Nv4500-5sp O/D 390cid
Owner for 3O great yrs.
Vietnam Vet 68-69
Driver of the Iron Butterfly
Gun Truck
And http://1971ford4x4.multiply.com/
  #12 (permalink)
Old 11-07-2009, 11:10 AM
orich's Avatar
I see a lot of trucks with these motors in the junk yards with the head pulled off that have valve troubles. So I would first Read the spark plugs then check the compression.Do a good tuneup. Plug wires may look good and may6be bad so Check wires with an ohm meter is the best way..
orich
__________________
Vietnam Vet 68-69
Gun Truck
Tags
1971 , 1990 , 300 , cab , crew , economy , efi , f150 , ford , fuel , poor , swap , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
