New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
11-08-2009, 12:32 AM
of FTE, RHN, and BEER!
Just so I'm sure, is this the EBPV that I've circled in the picture?
__________________
'01 F250 XLT ext cab, long bed, 4x4; 4" Diamond Eye turbo back exhaust; muffler delete; 6637 intake w/ custom cover from Pete's Filter Covers; I/C pipe foil delete mod; Transgo Tugger kit w/ Sonnax .427 valve; CCV mod; 3 pod A-pillar w/ ISSPRO boost, EGT, & trans temp; Zoodad mod; Mag-Hytec rear diff cover; 2 1/2" lift; Skyjacker Nitro shocks; Rancho steering stabilizer; Harpoon mod; DP Tuner w/ Stock, Hi-idle, 60T, 80E, and 120R.
11-08-2009, 12:48 AM
Negative, it is located on the exhaust side of the turbo basically behind the y-pipe, I'll go take a pic
__________________
Alan
2000 F-350 CC SRW 4WD
AIH delete, 6637 Filter, Wastegate Disable, Foil Delete, 50Cent Mod, Muffler delete 235,00 Miles and counting DP Tuner soon!
11-08-2009, 12:52 AM
Support FTE
Quote:
Originally Posted by
ztodd377
That is the AIT (air intake temp) sensor in the spider. The EBPV solenoid is at the bottom of the turbo pedestal.
11-08-2009, 12:59 AM
Here you go hope it helps find it!
__________________
Alan
11-08-2009, 01:00 AM
wow didn't know it was going to be so small! Click my name to view album.
__________________
Alan
11-08-2009, 01:04 AM
Maybe this will work
__________________
Alan
11-08-2009, 01:11 AM
Just realized how much I need to scrub behind Intake thanks!
__________________
Alan
11-08-2009, 09:10 AM
Jesus spoke a lot
1999 Ford F-550
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
11-08-2009, 08:22 PM
You guys are awesome. Thanks for all the help. I'm usually pretty good with most of this stuff. Can you look at my schematic and make sure I've got it right? And would a diode be necessary in there?
__________________
11-09-2009, 04:02 AM
Looks like your right on track to what you want, I personally don't see the need for the diode, unless you go with a really cheap switch, that might fail and feed voltage back to ECM, odds are in your favor though, against failure. Sounds like a good idea too based on your location. Most lower 48 just disconnect it but I see your reasoning!
__________________
Alan
11-10-2009, 01:09 AM
Thanks Alan. Think I'm gonna install it after work tomorrow.
__________________
Tags
73
73l
delete
diesel
difference
ebpv
f350
ford
fuel
location
psd
pump
shutoff
switch
turbo
years
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
