Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 11:49 PM
daboot daboot is offline
daboot is starting off with a positive reputation.
Throttle body spacer and AOD
I installed a 94 efi 351w in my 86 f150. The engine had a throttle body spacer on it. I left it on (it was running fine with it why take it off). Well here is the problem, the AOD has a early 2-3 (30mph) shift and 3-4 (35) shift. The mechanic said he cant adjust the cable correctly possibly because of the TB spacer. I have put over 200 mi on the trans shifting in to od at 50 mph. Do I need to remove the TB Spacer?
Thanks
  #2 (permalink)
Old 11-03-2009, 01:30 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Unless you want to fry the trans.....
  #3 (permalink)
Old 11-03-2009, 12:43 PM
The cable can't adjust for the additional 2 in of the TB Spacer. No one else ever had problems with this.
  #4 (permalink)
Old 11-03-2009, 01:06 PM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
You could probably make a custom cable.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #5 (permalink)
Old 11-03-2009, 03:37 PM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE. Lazy K is gaining momentum as a positive member of FTE.
Take the spacer off. A throttle body spacer may be of benefit with Chevys TBI setup but not much use with the superior Ford multi-point injection system.
Just my thoughts.
  #6 (permalink)
Old 11-03-2009, 03:53 PM
lew52's Avatar
lew52 lew52 is offline
lew52 is gaining momentum as a positive member of FTE.
What & lose the 500 HP , X2 chuck the spacer .... Lew
  #7 (permalink)
Old 11-03-2009, 06:51 PM
Quote:
Thats what I was thinking. Thanks for the help it will be off 2nite.
Tags
bad , body , ford , throttle , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
