Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 10:52 PM
Craigwell's Avatar
Craigwell Craigwell is offline
Craigwell is starting off with a positive reputation.
Maximum size tire for stock 8 bolt 16 x 6 rim (6.5?)
I have these rims for my 76 F250, currently running LT245/75R16 BFG All Terrain KO tires just fine.
The rims are stamped 16x6, but when I measure them they way I'm taught changing tires, with the caliper inside the balance weight flange, I read 6.5".
That's besides the point.
I am wondering what the largest set of tires is that I can run on these rims safely.
I want to run a 285/75R16 tire, or the loosely translated to inch style measurement would make it something like 33x11.25x16 (if such an animal existed tire wise, which I'm sure it doesnt)
See this link for size conversions: DML Tire and Wheel Calculator
Anyone have opinions on this?
Thank you.
__________________
1976 F250 4x4 300 six, T18. Ext Cab / Short Box. Pride of the Fleet.
1978 F150 2WD 351M/C6 Highway Star with 2.75 9".
1978/79 Bronco 300 Six Auto project for my wife. Making progress.
  #2 (permalink)
Old 11-03-2009, 04:31 AM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
The tire size you want will look and wear funny on 6" rims. You should have at least 8".
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #3 (permalink)
Old 11-03-2009, 09:31 AM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is starting off with a positive reputation.
Yeah, those side walls are gonna be pulled in big time. On my F250 I had 33 x 12.50 16.5 on 10 inch wide wheels. Yes they were measured in inches with a 16.5, 8-lug wheel. Technically the wheels and tires are still mine but I gave the truck back to my uncle. I am most likely going to buy a 1975 Highboy that I sold him back from him so then those wheels and tires will go on that.
__________________
1977 Ford F-150 4X4 460 4-speed (dark jade metallic) Produced June 22, 1977
1966 Ford Fairlane 289 2 door hard top (black)
  #4 (permalink)
Old 11-03-2009, 09:48 PM
Craigwell's Avatar
I first went hunting for my tires in inches, I was thinking something like a 33x9.50x16 or 16.5 would be ideal (I have both sets of rims, 16.5x6 and 16x6) - and quickly realized my options were limited in sizing like that for the tires I want.
Ideally I will run BFG All Terrain KO's, or Commercial Traction. (This is for plowing, where tall and skinny fit the bill for me).
Everything seemed ok with the 245/75R16's I had previously (All Terrain KO's), maybe I can get away with 265/75R16.
I am looking for other rims as well, but again, for plowing - steel fits the bill, not looking to add $1000 to what's already going to be a $1000 purchase.
Thanks
__________________
  #5 (permalink)
Old 11-15-2009, 05:56 PM
Craigwell's Avatar
Ok to follow up,
I have installed BFG Commercial Traction T/A. Class E load rated, 265/75R16. They seem to fit very well, no real sidewall bulging, etc. I have about 10 miles on them so far, and am quite happy. Thanks.
__________________
  #6 (permalink)
Old 11-15-2009, 06:17 PM
gstanfield's Avatar
gstanfield gstanfield is offline
gstanfield is starting off with a positive reputation.
For the narrower wheels why not run some 255/85R16's I ran them on my Ram2500 and they worked out great. They are essentially a 33x9.5x16 tire and work great on the stock width wheels. I have a set of 285/75R16 BFG's on 10" wide wheels on my F150 and they are actually about 1/2" shorter than the 255/85's on stock width wheels.
I know you already have them, but an idea for next time. The tall skinny 255/85's worked better in the snow than any other tire I've run on my Superduty and Ram 2500 that I've run out here in Wyoming winters.
George
  #7 (permalink)
Old 11-15-2009, 06:21 PM
Craigwell's Avatar
Yes, tall and skinny was the goal, there just wasn't the availability for me with the type of tires I wanted.
There is always next time, perhaps I'll go with a different supplier next time and see what I can get. Thank you.
__________________
  #8 (permalink)
Old 11-18-2009, 10:31 AM
terceslil's Avatar
terceslil terceslil is offline
1978 Ford F-250
terceslil is starting off with a positive reputation.
I have tall & skinny... These are 8"
__________________
Gallery 1978 F250 2WD Pickup built at the Norfolk plant in March 1978 and powered by a 8 cyl 400 cid 2-bbl engine.
http://i193.photobucket.com/albums/z316/brfuel/f250/f250-2.gif
  #9 (permalink)
Old 11-18-2009, 12:14 PM
75F350's Avatar
75F350 75F350 is online now
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
Just because I know this thread will pop up in a search, Ive found that running a real tall tire on stock wheels is not all that bad. Many have stated that the tire would deform to the point that it will wear funny, but in this pic you can actually see how much of the tire is contacting the ground. So far so good.
As a side note, airing down to single digit pressures have been a breeze. These have shown zero indication of coming off the wheel even at 3 and 4 psi.
Oh yeah, thats a 37" inch tire at 60 psi. When hese were adjused, they flatened out a bit. I run far less pressure and the wear is even and true.
Currently I run a wider wheel, but these still exist, and I have thrown these on he bronco as well as he red truck several times.
  #10 (permalink)
Old 11-18-2009, 07:33 PM
Craigwell's Avatar
I could have gone larger, but I didn't want this to be much considering I'm plowing and working this truck, not wheeling it.
__________________
Tags
16 , 1966 , 1976 , 1978 , 65 , bronco , f100 , f150 , f250 , ford , lt24575r16 , maximum , rims , size , sizes , stock , tire , tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
