Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 10:51 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke is gaining momentum as a positive member of FTE.
Can I check my calipers or just replace?
I have been having a brake gremlin show up every so often between my drivers side front and rear calipers. I haven't seen anything on the front since changing the brake hoses....probably need to do that on the back now. I have flushed the system...turned all four rotors, put on all new pads, re-lubed the glide pins, painted the e-brakes springs and tensioner in rear with nickel anti-seize compound...not sure what else to try. My rear drivers side is driving me crazy. I am to the point of replacement @ only (82K miles?)...Is there a way to check the calipers to see if they're okay...or should I just go ahead and replace? I know, the rotors could be warped, so replacing them too would be in order. I've checked the temps on the rotor that is hanging up and its around 650'F...probably not good. Let me know if you think I should replace them, and if so, any suggestions on where to get the replacements from. Thanks.
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, Lariat 4x4, 83k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant bypass, ZooDad, HighIdleMod, BullyDog 4" TB 4"DP (BullyDog ate Kitty), SCT SF3 Perf Strat, 24" Wipers, '08 Rear Diff Cover, Upfitters, Skyjacker/Russell brakes lines, M/C Max 100 BXT-65-850s, Mobil1 Syn 5W-40, Wagner ThermoQuiet's, Stanadyne Perf Add & FPPF Lubricity+Power Add., Prodigy Brake Controller, Nitrogen filled Bridgestone Dueller A/T Revo's, Satellite radio, Sun-visor.
  #2 (permalink)
Old 11-02-2009, 11:27 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
You don't say what it is doing other than heating up ?
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 11-03-2009, 07:50 AM
Quote:
Sure I did...(from previous post) " I've checked the temps on the rotor that is hanging up and its around 650'F...probably not good. " Not really sure how else I could describe it? Its not making any noise...but you can definately feel the drag....and compared to typical rotor temps of 140-190 for other rotors...650 seems a little high. So my question id (from those who have been where I am now)....do you think it is the caliper, and if so, where did you find your replacement? Thanks
__________________
  #4 (permalink)
Old 11-03-2009, 08:10 AM
Lazy K Lazy K is online now
Lazy K is gaining momentum as a positive member of FTE. Lazy K is gaining momentum as a positive member of FTE.
Have you checked that the parking brake is fully releasing on that side?
  #5 (permalink)
Old 11-03-2009, 11:14 PM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
Way too hot except if racing. The seals, grease, brake fluid, and bearings will not hold up to that temperature. If it was wood it would literally be on fire already.
You can buy pressure gauges that you insert between the pistons, but, kind of pricey at about $200.00
I would just replace the calipers, seals, and maybe the bearings and completely flush the whole system, I would think about replacing the hoses on that side again.
The other thing is if you have 4 wheel ABS it might actually be the valve itself.
I have never worked on a 2005 so I can't say if your system is the same on say a Land Rover 3. But, with two calipers on the same side overheating, I would tend to think it was a valving issue with a 4 wheel ABS system. I would fix that and then replace the calipers and hoses.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #6 (permalink)
Old 11-04-2009, 08:36 AM
mark a.'s Avatar
Jack it up try to spin it. See if it turns free, go from there.
__________________
Tags
2000 , 2001 , brake , caliper , calipers , check , f150 , f250 , ford , replace , replacement , replacing , seals , temp , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
