Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 10:50 PM
branden.w's Avatar
branden.w branden.w is offline
branden.w is starting off with a positive reputation.
smoking ignition wires, no starter response
i posted something about this earlier but was wondering. its smoking where the ignition wires are spliced together, and the tape looks kinda melted and hard, does the smoke mean thats where the ground problem is or where its just releasing all the heat at that splice point?
  #2 (permalink)
Old 11-02-2009, 11:33 PM
rupejosh's Avatar
rupejosh rupejosh is online now
1994 Ford F-250
rupejosh is starting off with a positive reputation.
i would say its the weak part of the wiring and the splice is shot.just cut the splice out and take 2-3" of each side of the wire and splice in a new wire but trace the wire as far as you can checking for bad spots
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
  #3 (permalink)
Old 11-02-2009, 11:35 PM
joe f350's Avatar
joe f350 joe f350 is online now
joe f350 is gaining momentum as a positive member of FTE.
smoking and wiring never a good thing when u put them together
__________________
85 ford f350 lifted 11 inch 37 6.9 t19 my freinds call it the panzer
  #4 (permalink)
Old 11-03-2009, 12:46 AM
branden.w's Avatar
yea i know, its not a good thing, lol
  #5 (permalink)
Old 11-03-2009, 02:54 AM
joe f350's Avatar
form my hanes maunle for these truck to check solenoid connect jumper wire a between the battery (+)and the ignition switch wire terminal (the small terminal) on the solenoid if the starter motor operates the solenoid is okay and the problem is in the ignition switch neutral start switch or the wires it was a lot of typing so don't put it to wast
__________________
  #6 (permalink)
Old 11-03-2009, 03:10 AM
branden.w's Avatar
lol, im gonna try it tomorrow mornin thanks alot bro
  #7 (permalink)
Old 11-03-2009, 03:13 AM
joe f350's Avatar
not prob i hope u will get ur truck back on the road u allso might try to seash so for the older post there a gold mine of info
__________________
  #8 (permalink)
Old 11-03-2009, 07:36 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250 WEST AUSSIE 94 250 is offline
1994 Ford F-250
My Garage
WEST AUSSIE 94 250 is starting off with a positive reputation.
All electrical components have a small amount of "MAGIC WHITE SMOKE" within them. Once the aforementioned smoke escapes the confines of the component it is usless.Swearing is usually followed by component replacement which may or may not be accompanied by hip pocket pain and neck pain, as in getting it in the neck from the significant other.
__________________
FRANK
94 7.3 FACTORY TURBO E40D EXTRA CAB 4X4. FULL ALUMINIUM BARWORK AND TRAY. RHD CONVERSION.http://www.ford-trucks.com/forums/im...ine=1249653189
  #9 (permalink)
Old 11-03-2009, 09:42 AM
timothyr timothyr is online now
timothyr is starting off with a positive reputation.
brandon,
Keep in mind a direct bi-product of resistance is heat, and a bad splice can cuase alot of resistance, so I would start there.
If you are seeing what looks like melted and hard electrical tape your splice is deffinatly bad and like someone said earlier, cut out 2 to 3 inches and solder in a section of wire. Even if you can temporarily make it work it will get worse...as the tape heats up it liquifies and will flow between the wire strands effectivly insulating them and creating more heat, and the cycle goes on till you break out the marshmellows and start singing kumbaya
__________________
86 F350 Crew Cab Dually - 6.9l IDI w/a 4-spd
Tags
2003 , 96 , f250 , ford , ignition , response , starter , wires , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
