Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 10:50 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke is gaining momentum as a positive member of FTE.
Can I test my brake calipers?
I have been having a brake gremlin show up every so often between my drivers side front and rear calipers. I haven't seen anything on the front since changing the brake hoses....probably need to do that on the back now. I have flushed the system...turned all four rotors, put on all new pads, re-lubed the glide pins, painted the e-brakes springs and tensioner in rear with nickel anti-seize compound...not sure what else to try. My rear drivers side is driving me crazy. I am to the point of replacement @ only (82K miles?)...Is there a way to check the calipers to see if they're okay...or should I just go ahead and replace? I know, the rotors could be warped, so replacing them too would be in order. I've checked the temps on the rotor that is hanging up and its around 650'F...probably not good. Let me know if you think I should replace them, and if so, any suggestions on where to get the replacements from. Thanks.
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, Lariat 4x4, 83k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant bypass, ZooDad, BullyDog 4" TB 4"DP (BullyDog ate Kitty), SCT SF3 Perf Strat, 24" Wipers, '08 Rear Diff Cover, Upfitters, Skyjacker/Russell brakes lines, M/C Max 100 BXT-65-850s, Mobil1 Syn 5W-40, Wagner ThermoQuiet's, Stanadyne Perf Add & FPPF Lubricity+Power Add., Prodigy Brake Controller, Nitrogen filled Bridgestone Dueller A/T Revo's, Satellite radio, Sun-visor.
  #2 (permalink)
Old 11-02-2009, 11:54 PM
Chris1450 Chris1450 is offline
Chris1450 is starting off with a positive reputation.
Quote:
I had a problem with the rear passanger side sticking. The brake pads where wearing uneven indicating a stuck piston. I bought 2 rear rebuilt calipers for $41 each and ceramic pads for $44. Very cheap to fix the problem. It is hard to determine that a piston was sticking.. other than the uneven wear. I would bet your having the same problem. BTW.. my truck has 90,000 miles
  #3 (permalink)
Old 11-03-2009, 05:51 AM
slowmans slowmans is offline
slowmans is starting off with a positive reputation.
I noticed I am having a similar issue, when driving on the highway this weekend the truck felt like it was dragging a little, so I opened the back window and sure enough I could smell em burning up, so I pulled over and shut the truck down and sure enough the rear pass, side was smoking a bit , I started on my way again and couldn't feel it anymore....its been fine since. I do need to check em out though.
__________________
2006 F350 LARIAT 6.0 SUPERCAB 4X4 FX4
4"MBRP T-409 TURBO BACK COOL DUALS
EDELBROCK PERFORMER IAS SHOCKS
ACCUFAB POLISHED INTAKE ELBOW
KITTY IS AT THE VET!!!
305/65/18 BFG ALL-TERRAINS
DRINKING B-5 REGULARLY
08' REAR DIFF. COVER
  #4 (permalink)
Old 11-03-2009, 09:46 AM
gearloose1 gearloose1 is offline
gearloose1 is starting off with a positive reputation.
Factory rebuilts from a reputable place that actually checks everything for spec and use good quality parts is the way to go.
  #5 (permalink)
Old 11-03-2009, 11:10 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE.
I think mine are doing the same thing, on my way to work this morning, the force and power the engine was putting out didn't match the forward motion of the truck...know what I mean?
I could also hear the brakes squealing ever so slightly at low speeds, so brake job this weekend....
__________________
If you live in Texas and need help with your truck, PM me.
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
Tags
2000 , brake , brakes , buckley , excursion , ford , good , hanging , place , rear , wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
