I have a gauge hooked up to the shrader valve. It is a little hard to get a good reading because I am using an air filled gauge, not the glicerin filled, so the needle bounces pretty good with the pulses. Trying to average the pulses at idle it is around 50 psi but when driving it will drop down and can go as low as around 30 psi. Should it stay up at 50 no matter or is it suppose to drop? I would say the FPR is ok because of the pressure at idle but more like a fuel supply problem? What would cause it and how much to fix if it is the problem? Thanks.
__________________
Jim-1996 F250 CC Shorty 4X4 E4OD 7.3L Diesel
Mods: 6637 air filter,203 F t-stat from Diesel Site-finally heat! HPX line, Tymar 3-4 dp to 4" exhaust, E4OD "The Cure" 30K mod for now, 140IDM mod, ISSPRO ev1 egt, trans temp, boost, adrenaline HPOP med-oil
Powerstroke - IF your not being blown, your just sucking.
it will vary as the demand changes. you dont want it dropping too low, 45-50 is about the norm. you can shim the regulator with a bb to bump it up to 80 psi which happens to be the max "safe" limit in the ford manual. this will help out with the drop in pressure.
So increasing the fuel pressure will help it keep up with the demand better? I was thinking it was a fuel supply problem which was resulting in the drop of psi. I need to get a glicerin filled one to get a better reading anyways.
__________________
The FPR shim is installing a BB under the spring inside the plunger on the Fuel Pressure Regulator. On the top of the FPR there is a 3/4" plug. Unscrew it, carfully remove the spring. Then use a magnet or needle nose pliers and remove the plunger. Install the BB inside the plunger, install the spring and install the assembly in the FPR. Be careful not to bend the spring when reinstalling the plug. This is one of the easier mods.
Check the fuel pressure before you install the BB. If it is over 60PSI you do not need to do this mod.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <>< 95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v 2000 Ranger 4X4 No MODS, yet!
If your gauge has a rubber hose, the old trick is to slowly pinch off the line
with needle nose pliers or something. It will give you the reading.
With a drop in pressure the bb is just going to buy you time. You have caught
an issue in the fuel system in its infant stage.
Your pressure fall is most likley from lack of volume.
61-62 psi is what most tuners use for a baseline fuel pressure.
I will have to try pinching the line. That is what I was kind of thinking also because at idle the psi is in an acceptable range. I can try the bb and see what happens.
__________________
Thats strange cause i was reading 55 from a new pump. so i shimmed it now it is at 80 psi. i also replaced the bowl. I was xtold factory psi was around 55 psi.
__________________
Ronnie Warfield
1995 F 250 Turbo diesel reg cab 2wd
6637 mod, 3 inch dp, lost kitty, GPR mod, SD 120v idm, 2500 watt inverter
Maryland Chapter member
Not strange. His pressure drops.
Correct test is idle pressure 1st, then hold the throttle to the floor
for the 2nd pressure test. It should rise in the 2nd test.(mech pump)
(aftermarket chip removed for test)
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
