Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-03-2009, 08:34 PM
wildstang wildstang is offline
wildstang is starting off with a positive reputation.
Do our fuel systems dead head like the superduty or do they have a return line? If it has a return line, would it be less likely to trap air?
__________________
Jim-1996 F250 CC Shorty 4X4 E4OD 7.3L Diesel
Mods: 6637 air filter,203 F t-stat from Diesel Site-finally heat! HPX line, Tymar 3-4 dp to 4" exhaust, E4OD "The Cure" 30K mod for now, 140IDM mod, ISSPRO ev1 egt, trans temp, boost, adrenaline HPOP med-oil
Powerstroke - IF your not being blown, your just sucking.
  #17 (permalink)
Old 11-03-2009, 08:40 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is gaining momentum as a positive member of FTE.
There is a return. Cuda posted a pic of the fuel system a in a thread a couple of days ago. My guess is the fuel tank switch thingy that I can't remember the name of.
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
  #18 (permalink)
Old 11-03-2009, 08:42 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar is starting off with a positive reputation.
i am not 100% sure but i would think it has a return system. I hope madvan will chime in on this
__________________
Ronnie Warfield
1995 F 250 Turbo diesel reg cab 2wd
6637 mod, 3 inch dp, lost kitty, GPR mod, SD 120v idm, 2500 watt inverter
Maryland Chapter member
  #19 (permalink)
Old 11-03-2009, 10:16 PM
nateairman's Avatar
nateairman nateairman is offline
nateairman is starting off with a positive reputation.
I tested my system this morning and was running at 30 to high 40s at idle. I put in a new mechanical pump a year ago. After putting the bb in I was in 40-60 range. The needle was bouncing pretty good so I choose the average to high range of needle motion. Tomorrow I will check it with a stick gauge for fun.
I am curious to what the mid rpm to high rpm miss is in first and second gear. It seems to go away in third and fourth. Some times it is accompanied with a whiteish blue smoke.
  #20 (permalink)
Old 11-03-2009, 10:26 PM
pjwoolw's Avatar
WAG on the smoke is injector o rings.
__________________
Pete in San Ramon
  #21 (permalink)
Old 11-03-2009, 10:32 PM
nateairman's Avatar
I am very new to this truck and still trying to figure out all the acronyms.. WAG? should I put in an injector o-ring kit or all new injectors.
Last edited by nateairman; 11-03-2009 at 10:51 PM. Reason: WAG: Scientific Accurate Guess
  #22 (permalink)
Old 11-03-2009, 11:06 PM
rodneywar's Avatar
You injector orings are on its way out not the actual injectors. Btw what is WAG idk too
__________________
Ronnie Warfield
  #23 (permalink)
Old 11-03-2009, 11:07 PM
pjwoolw's Avatar
Wild A** Guess!
__________________
Pete in San Ramon
  #24 (permalink)
Old 11-03-2009, 11:58 PM
rodneywar's Avatar
Thanks Pete you made my night
__________________
Ronnie Warfield
  #25 (permalink)
Old 11-05-2009, 09:56 PM
Well I may not have a pressure problem. I got my glicerin filled gauge today and put it on, still a little oscillation but fairly stable. At idle it is around 55psi and is for the most part stayed in the 50's. I was able to get it down to almost 40. The highest I have seen so far was around 65. The air gauge I was using had a lot of oscillation. It looked like it was droping down to 30 or so and up to 70 or higher.
On a side note I did get it up to 20psi for boost going up a short steep hill.
__________________
Tags
ford , gas , low , pressure
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
