Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-07-2009, 05:56 PM
FordMuddin' FordMuddin' is offline
FordMuddin' is starting off with a positive reputation.
with the 2" lift add a leaf kit i just stumbled apon (Skyjacker 1967-77 Ford F250 High Boy 4WD 2" Lift Kit) Would the steering have to be altered or could everything stay the same? Would just the add a leafs be all i would need?
I just saw on one thread that 38's are SUPPOSED to fit stock on a brand new highboy, so i figured maybe by replacing all springs along with an add-a-leaf that some 38.5's would fit perfectly.
  #17 (permalink)
Old 11-07-2009, 06:00 PM
they make the same kit in 4" as well. (Skyjacker 1967-77 Ford F250 High Boy 4WD 4" Lift Kit)
Would i need to alter the steering for this kit as well?
Thanks
  #18 (permalink)
Old 11-14-2009, 12:23 PM
I'm going to take a look at the truck today. . . it won't be started up though because the owner is in florida so he is just having his son show it to us and his son doesn't know where the keys are. lets hope it looks nice.
__________________
15 and ready to start buildin' the first mudder. . . as soon as i get a truck that is
  #19 (permalink)
Old 11-14-2009, 12:34 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is starting off with a positive reputation.
Quote:
Connect a power wire to the positive side of the coil then jump the solenoid with a screwdriver, problem solved. No keys required.
__________________
1977 Ford F-150 4X4 460 4-speed (dark jade metallic) Produced June 22, 1977
1966 Ford Fairlane 289 2 door hard top (black)
  #20 (permalink)
Old 11-14-2009, 01:16 PM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
Hot starting old fords is easy. As mentioned above it can be a piece of cake, however, it is also just as easy to purchase a complete key assembly at your local parts store, and siimply unplug the harness from the old switch abd connect it to the new one. Then you can operate the truck normally.
For a small investment, this option is reasonable. Plus, it might be something that you will have to purchase anyway.
  #21 (permalink)
Old 11-14-2009, 08:28 PM
i took a look at it today. It NEEDS headers. THe old ones are rusted through, you could put your finger through one side of a pipe on the headers and out the other. the shifter shaft is really crooked and facing sideways (are the shifter shafts unscrewable so that i could just screw it in the rest of the way until its facing normal?) the sidepanel on the door is ripped up and quite frankly pretty floppy, the seat is also ripped up right to/and through some of the foam so a new seat would be needed, but other than that the truck seems to be pretty good (and it need a powersteering assist valve. . . anyone know how much a new one would cost, like 8.99?)
Thanks.
__________________
Tags
1973 , 77 , axle , box , f250 , ford , front , highboy , kit , lift , recommended , sale , specs , springs , steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
