Limited-slip Rear end
This may be a stupid question but, is there anyway to lock a limited-slip rear end. How exactly does limited-slip work is it electronic, can I enguage it by a toggle switch, or would I have to just install a posi lock locker. I don't want to weld it because I still use the truck as a daily driver. It can be a pain in the *** to have one rear tire spin and my truck almost get stuck before I stop and lock the hubs. Any answers would be helpful. thanks.
That's called a Lincoln locker, and really should not be used on a DD that see's mostly pavement. The stock LS is garbage, it works based on a clutch pack engaging when one tire breaks loose, but it doesn't ever seem to hold up in the real world. Buy either an Eaton LS unit, or just spring for a Detroit locker, they won't ever fail in a stock setup
change the fluid and get the friction modifier, this helps quite a bit, I installed a truetrack and I love it ( all kinds of traction)
Well the trucks still under warranty, and i'm broke college student. So I'll have to wait to get back to a summer job to buy a truetrac
Since you all are being so helpful today. I have a transfer case problem too:
I will be rolling up to a stop sign and flip the switch in 4x4 I hear it engage, the 4x4 light comes on. I come to stop, proceed away from the stop sign, at this point there is a loud slam, the truck is now in 2wd, there is lots of grinding noises, another loud slam, and it now stays in 4x4 until I switch it back to 2wd. I took it to the dealer, the said the changed a solenoid, didnt help. The snow up here will not work with me and the roads are always clear when I have time to take it in. you guys got any leads that I can give them when I take it in. The guys there just look at me like im crazy and this is impossible.
change the fluid and use less or NO friction modifier... when i did my fluid i only used half the recommended friction modifier and it still didnt improve the LS much. next time i don't plan on using any.
With Redline 75W140, I used 0 modifier and my LSD works great, even with 160K miles and bone stock original diff. It was fun pulling all the diesels out of the sand! I would consistently fling sand with 3 tires.
When you say yours only spins one tire now days, is the LS suppose to spin both? I thought LS meant if one tire spins the other one stays tracking?
Can someone also further explain the difference between a locker rear end and a posi?
I'm just not a fan of the "one wheel peel" (catch s**t from my buddies all the time because of it), and i don't have the $ right now to invest in an aftermarket one like you guys are speaking of.
Thanks, btw I have a 2007 f250 PSD.
