Rear End Gears: - Ford Truck Enthusiasts Forums
Rear End Gears:
Old 11-02-2009, 09:30 PM
BigRed1967's Avatar
BigRed1967 BigRed1967 is offline
BigRed1967 is starting off with a positive reputation.
Smile Rear End Gears:
I have a 1977 Ford F250 2WD and I have 4:11 rear end gears, I was thinking on going with 3:55, what are your thoughts on this folks? Is 3:55 a good choice, I want gears that are better for the highway.
thanks
BigRed
Old 11-02-2009, 10:27 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Auto or stick ?
Old 11-03-2009, 12:09 AM
BigRed1967's Avatar
Rear End Gears:
My truck is an automatic.
Old 11-03-2009, 08:09 AM
Kionga's Avatar
Kionga Kionga is offline
Kionga is starting off with a positive reputation.
RE:Rear End Gears
I have a 1978 F100 with 400 motor and FMX tranny. Tyres are 235/75/15 and run a 3.55 rear diff. Seems to run on the highway agreeably, but still has good bottom end torque.
Craig
Old 11-03-2009, 08:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
If you have an FMX, it was swapped in from a passenger car.
The ONLY F Series trucks to have an FMX were 1973/77 F350's with 300 I-6's.
The original and only A/T for your truck is the C6.
FMX = 14 trans pan bolt holes / C6 = 17 trans pan bolt holes.
Old 11-03-2009, 08:35 AM
4x4 Bart 4x4 Bart is offline
4x4 Bart is gaining momentum as a positive member of FTE.
3.55 will run good on the highway.
Old 11-03-2009, 09:41 PM
peterbilttrucker's Avatar
peterbilttrucker peterbilttrucker is offline
peterbilttrucker is starting off with a positive reputation.
I have 3.55s in mine (with a 460) and I LOVE it!
Good luck getting the speedometer right.
Old 11-03-2009, 11:01 PM
Kionga's Avatar
FMX?
Thanks for the information about the FMX Bill. I had read that FMX's were used in F350's but did not know the engine used. Yes, I can confirm that my tranny is an FMX since I obtained it from a passenger car. I obtained a big block bell housing for an FMX from the USA. Put a shift kit in and works like a dream.
Craig.
Old 11-05-2009, 07:57 PM
BigRed1967's Avatar
Rear End Gears:
Hi everyone, where is a good place to buy rear end gears in the Calgary, Alberta area?
Old 11-05-2009, 08:07 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
I've got 3.50s in my F150 with a 460 and I think they are perfect. I don't feel the need for OD at all with 33 inch tires, but I do have the granny low and low Range if they are too high for something.
Also my dad has a 1979 full time auto F250 with a 429. It has 3.55s and are great with the automatic trans as well. I would go for it. The speedo shouldn't be that big of a problem. I know on 80s/90s Mustangs there is a chart to get the correct speedo gear so I would assume you could find something similar to obtain the correct speedo gear.
Ive never heard of an FMX in a truck, and I had no idea they were offered from the factory, interesting. Speaking of things along those lines. A C4 auto trans has a removable bellhousing. I have a bell housing to put a C4 behind a 460! Not something you see every day. I had a project that never got finished where I was stripping a 1981 Mustang to be as light as possible and I was gonna use a junkyard 460 with a C4 (lighter and uses less power than a C6) and see how fast I could go for extremely cheap. I still have every thing just never materialized, got too much else going on. My bell housing came from a car that would have had a 351m or 400. I don't think a C4 actually ever came behind a 460.
Old 11-06-2009, 04:29 AM
The plastic speedometer DRIVEN gears (at the end of the cable) are the same from 1960 thru today for cars & trucks, so are available from Ford.
The prices range from $2.00 to $3.76...each.
16-17-18-19-20 & 21 tooth gears are offered.
No C4's were used with 400, 429/460 or FE engines.
Some 1975/79 passenger cars with 351M's used the C4.
Other Passenger Car / F100/350 / Bronco / Econoline engines with C4's: 2.3L I-4 // 200/240/250/300 I-6's // 3.8L V6 // 255/260/289/302/351C 2V/351W.
E350 rear end gear change moosey78 1968-2013 Full Size Vans 21 03-19-2014 06:45 PM
1977 ford F250 Dana 60 gear choice: BigRed1967 1973 - 1979 F-100 & Larger F-Series Trucks 11 12-02-2009 10:56 AM
Rear End: BigRed1967 1973 - 1979 F-100 & Larger F-Series Trucks 14 11-08-2009 07:35 AM
manual vs automatic tranny bigred66 1978 - 1996 Big Bronco 7 10-25-2007 01:26 PM
rear end jelzy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 12-28-2003 02:36 AM
Tags
1977, 78, 96, alberta, bronco, c6, end, ford, gear, gears, moter, numbers, parts, rear, rearend, speedometer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
