Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 09:30 PM
BigRed1967's Avatar
BigRed1967 BigRed1967 is offline
1977 Ford F-250
My Garage
BigRed1967 is starting off with a positive reputation.
Smile Rear End Gears:
I have a 1977 Ford F250 2WD and I have 4:11 rear end gears, I was thinking on going with 3:55, what are your thoughts on this folks? Is 3:55 a good choice, I want gears that are better for the highway.
thanks
BigRed
  #2 (permalink)
Old 11-02-2009, 10:27 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Auto or stick ?
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 11-03-2009, 12:09 AM
BigRed1967's Avatar
1977 Ford F-250
My Garage
Rear End Gears:
My truck is an automatic.
  #4 (permalink)
Old 11-03-2009, 08:09 AM
Kionga's Avatar
Kionga Kionga is offline
Kionga is starting off with a positive reputation.
RE:Rear End Gears
I have a 1978 F100 with 400 motor and FMX tranny. Tyres are 235/75/15 and run a 3.55 rear diff. Seems to run on the highway agreeably, but still has good bottom end torque.
Craig
  #5 (permalink)
Old 11-03-2009, 08:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
If you have an FMX, it was swapped in from a passenger car.
The ONLY F Series trucks to have an FMX were 1973/77 F350's with 300 I-6's.
The original and only A/T for your truck is the C6.
FMX = 14 trans pan bolt holes / C6 = 17 trans pan bolt holes.
__________________
Bill / Retired Ford Partsman (1962/97) / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Passenger Cars: 1928/89.
  #6 (permalink)
Old 11-03-2009, 08:35 AM
4x4 Bart 4x4 Bart is offline
4x4 Bart is starting off with a positive reputation.
3.55 will run good on the highway.
  #7 (permalink)
Old 11-03-2009, 09:41 PM
peterbilttrucker's Avatar
peterbilttrucker peterbilttrucker is offline
peterbilttrucker is starting off with a positive reputation.
I have 3.55s in mine (with a 460) and I LOVE it!
Good luck getting the speedometer right.
__________________
I'da been here sooner if I'd gotten here before I did.
  #8 (permalink)
Old 11-03-2009, 11:01 PM
Kionga's Avatar
FMX?
Thanks for the information about the FMX Bill. I had read that FMX's were used in F350's but did not know the engine used. Yes, I can confirm that my tranny is an FMX since I obtained it from a passenger car. I obtained a big block bell housing for an FMX from the USA. Put a shift kit in and works like a dream.
Craig.
  #9 (permalink)
Old 11-05-2009, 07:57 PM
BigRed1967's Avatar
1977 Ford F-250
My Garage
Rear End Gears:
Hi everyone, where is a good place to buy rear end gears in the Calgary, Alberta area?
  #10 (permalink)
Old 11-05-2009, 08:07 PM
Blown 331's Avatar
Blown 331 Blown 331 is online now
Blown 331 is starting off with a positive reputation.
I've got 3.50s in my F150 with a 460 and I think they are perfect. I don't feel the need for OD at all with 33 inch tires, but I do have the granny low and low Range if they are too high for something.
Also my dad has a 1979 full time auto F250 with a 429. It has 3.55s and are great with the automatic trans as well. I would go for it. The speedo shouldn't be that big of a problem. I know on 80s/90s Mustangs there is a chart to get the correct speedo gear so I would assume you could find something similar to obtain the correct speedo gear.
Ive never heard of an FMX in a truck, and I had no idea they were offered from the factory, interesting. Speaking of things along those lines. A C4 auto trans has a removable bellhousing. I have a bell housing to put a C4 behind a 460! Not something you see every day. I had a project that never got finished where I was stripping a 1981 Mustang to be as light as possible and I was gonna use a junkyard 460 with a C4 (lighter and uses less power than a C6) and see how fast I could go for extremely cheap. I still have every thing just never materialized, got too much else going on. My bell housing came from a car that would have had a 351m or 400. I don't think a C4 actually ever came behind a 460.
__________________
1977 Ford F-150 4X4 460 4-speed (dark jade metallic) Produced June 22, 1977
1966 Ford Fairlane 289 2 door hard top (black)
  #11 (permalink)
Old 11-06-2009, 04:29 AM
Ford Parts Guru
The plastic speedometer DRIVEN gears (at the end of the cable) are the same from 1960 thru today for cars & trucks, so are available from Ford.
The prices range from $2.00 to $3.76...each.
16-17-18-19-20 & 21 tooth gears are offered.
No C4's were used with 400, 429/460 or FE engines.
Some 1975/79 passenger cars with 351M's used the C4.
Other Passenger Car / F100/350 / Bronco / Econoline engines with C4's: 2.3L I-4 // 200/240/250/300 I-6's // 3.8L V6 // 255/260/289/302/351C 2V/351W.
__________________
Tags
78 , 96 , alberta , bronco , c6 , ford , gear , gears , moter , numbers , parts , rearend , speedometer , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
