Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 08:49 PM
dgsm24's Avatar
dgsm24 dgsm24 is offline
dgsm24 is starting off with a positive reputation.
What do you guys think i should do?
So my check engine light was on...took it the the "zone" and found a leak in my PCV hose.....Fixed that and it ran worse! Found a couple small vacuum lines had holes in them, and fixed that and still ran bad! A new code poped up. P1400 so i bought a new dpfe sensor and it STILL ran like crap(at idle). The hole time the EGR vacuum regulator was making a weird noise( a vibrating noise after i shut the truck off). Soooo the part comes in tom morning and i am gonna replace that, but i returned the dpfe sensor because the truck ran the same way.....Can you guys think of anything im missing? When i replaced the dpfe i disconnected the batt and put it in, conn the battery....started it up drove it did the same thing....any ideas? Should the egr vacuum regulator fix my problem? Thanks all...oh yea proud new owner of a 97 f150 4x4 4.6 single cab reg bed!!!!!
  #2 (permalink)
Old 11-03-2009, 12:35 AM
ole_smokey_88's Avatar
ole_smokey_88 ole_smokey_88 is offline
2002 Ford F-150
My Garage
ole_smokey_88 is starting off with a positive reputation.
what did the first code read ?
__________________
1988 F-150 5.8ltr aka "Ole Smokey"
1989 F-150 4.9ltr "For sale"
2002 F-150 5.4ltr aka "Newbi"
  #3 (permalink)
Old 11-03-2009, 07:50 AM
dgsm24's Avatar
um i dont remember the code but it had 2 or 3 emission leaks
  #4 (permalink)
Old 11-03-2009, 09:44 AM
Joe Finn's Avatar
Joe Finn Joe Finn is online now
Joe Finn is starting off with a positive reputation.
You need to get the exact code(s). Once you have that, you'll get some good recommendations on how to fix.
__________________
'97 F150 4x4 XLT 4.6L 3.55 LS Supercab
  #5 (permalink)
Old 11-03-2009, 05:49 PM
dgsm24's Avatar
the codes that were showing before were just emissions leak because my pcv hose was leaking once that was fixed the check engine light was cleared and the truck stalled leaving the "zone" the new code that shows now is P1400ive replaced the dpfe the egr syleniod and still nothing, i also traced the vacuum lines and they all look good
  #6 (permalink)
Old 11-03-2009, 10:54 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
EGR differential pressure low voltage noted---- the new switch might fix that code 1400. I question if you have other problems. 12 year old truck, new to you, unknown history?? I thinking its time to get spark plugs, check COP wires, fuel filter, pull vacuum hoses and check for flexibility/ cracks/ burn and replace, etc...
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 190,000 miles
2002 Explorer 4 x 4 4.0 XLT - 120,000 miles
  #7 (permalink)
Old 11-03-2009, 11:05 PM
dgsm24's Avatar
ok steve, thank you, is weird how this all happened i only had the vacuum leak code and i fixed it and the truck ran worse....today i sprayed the connection with some spray cleaner and it actually doesnt die anymore, still idles a lil lower then it did but itll do for now, what are COP wires by the way? and does anyone sell the small plastic OEM vacuum lines( the little tiny ones that are inside the black tube that run through all the emissions.....thanks again steve for the info!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
