Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 07:48 PM
1965 f-500 1965 f-500 is offline
1965 f-500 is starting off with a positive reputation.
1965 ford vin
is the warranty number on the warranty plate the same as the vin.
  #2 (permalink)
Old 11-02-2009, 08:04 PM
banjopicker66's Avatar
banjopicker66 banjopicker66 is offline
In Occupied CSA
banjopicker66 is gaining momentum as a positive member of FTE. banjopicker66 is gaining momentum as a positive member of FTE.
Short answer - Yes.
Long answer - You meed to confirm that the Warranty Plate number matches the VIN stamped on the frame.
You will find it on the passenger side rail, ahead of the of the cross member, but behind the core support, about where the alternator sits on a V-8.
The stampings are light, so you'll need to be careful when uncovering it. Don't use a grinder, but use a wire brush.
__________________
1966 F-100 460, C6, power disc brakes, power steering
2000 F-250 SuperDuty 7.3L Diesel 150K, pillar gauges, oil drain valve - Infected with PMS.
He is no fool who gives up what he cannot keep to gain what he cannot lose! (cf Mt 16: 25, 26)
Deo Vindice!
  #3 (permalink)
Old 11-02-2009, 08:17 PM
thank you for the info.
  #4 (permalink)
Old 11-03-2009, 09:17 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by 1965 f-500 View Post
is the warranty number on the warranty plate the same as the vin. Yes.
Welcome to FTE
The VIN is located on the Warranty Plate...which is riveted onto the face of the left door below the latch.
Compare the VIN on the Warranty Plate with the VIN on your trucks registration to see if they match.
People replaced damaged left doors with used doors. 99% of the time, they did not install the original Warranty Plate on the replaced door.
While this is not common, it is not un-common either. F500: The VIN begins with F50.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #5 (permalink)
Old 11-03-2009, 04:23 PM
the warranty number and the vin on the frame dont match. the warranty number says not for titling. so do i use the one on the frame.
  #6 (permalink)
Old 11-03-2009, 04:32 PM
Ford Parts Guru
The Warranty Number is the same as the VIN = Vehicle Identifcation Number.
If the VIN on the Warranty Plate (located on the left door face) does not match the VIN on the registration, or on the frame...the door has been changed.
1961/66: Any door from any F100 thru F1100 will bolt on.
__________________
  #7 (permalink)
Old 11-03-2009, 07:14 PM
F250GH F250GH is offline
F250GH is starting off with a positive reputation.
Use the frame stamped VIN for your registration. You can have a correct replacement door tag made by Backeast.
  #8 (permalink)
Old 11-07-2009, 01:59 PM
since the warranty number is the same as the vin why does it say not for titling purposes
  #9 (permalink)
Old 11-07-2009, 02:41 PM
EricJ EricJ is offline
EricJ is starting off with a positive reputation.
Because the registry may not accept the riveted on # plate on the door as the actual VIN of the truck without verifying with the frame Stamping.
Most registry cops I know are too lazy to look so it's generally not an issue.
  #10 (permalink)
Old 11-07-2009, 04:48 PM
In Occupied CSA
It wasn't used for titling purposes because it is too easily changed. You can remove and replace those little "rivets" that hold the Warranty Plate on with a fingernail.
And, most states nowadays DO look at VINs - check out CNN about the VW bus bound for Europe after being stolen 35 years ago. E-bay was the biggest motivation for states to tighten up their shot group on this.
States that I know that check stamped VINs are WA, MD, VA, AZ and PA for sure.
__________________
Deo Vindice!
Tags
1965 , antique , decoder , door , ford , fords , galaxie , list , location , number , original , pickup , plate , vin , warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
