Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 07:39 PM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer is starting off with a positive reputation.
Why EFI plugs?
Hey, guys--
I'm building a hp 300 from 1975, with an '81 head. I was wondering why most hp builds go with the EFI plug? Can some one explain why I should go that route? Are we striving to get as close to a Hemi head as possible?
Thanks
  #2 (permalink)
Old 11-02-2009, 08:41 PM
NavyMIDN08's Avatar
NavyMIDN08 NavyMIDN08 is offline
NavyMIDN08 is starting off with a positive reputation.
are you talking about the spark plugs? a hemi head is named that way for the shape of the combustion chamber, and coorespondingly the positioning of the intake and exhaust valves. the combustion chamber is half a sphere, or hemispherical... a hemi... it has nothing to do with the plugs. there are a million different opinions on why to choose a spark plug, how to index them, how to gap, etc... i'm not sure what it is youre looking for?
__________________
If it ain't broke, you ain't worked it hard enough...
  #3 (permalink)
Old 11-02-2009, 09:30 PM
Am I mistaken to believe that on a Hemi head, the spark plug screws straight down into the center of the combustion chamber?
And if that is the case, my question is if by using a longer plug, the EFI plug, one is trying to get as close to the center of the chamber as possible, thereby nearly dublicating the effectiveness of the Hemi head, or trying to get as close to it as possible. That is what I meant.
  #4 (permalink)
Old 11-03-2009, 12:54 AM
Harte3 Harte3 is offline
Harte3 is starting off with a positive reputation.
Not a scientific response but...I suspect it's for the same reason OEM went with the extended reach plug on the EFI engine much like some of us use the EFI exhaust manifolds as a poor man's upgraded exhaust system on a carbed engine...a wee bit more performance and/or efficiency.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
  #5 (permalink)
Old 11-03-2009, 09:01 AM
NavyMIDN08's Avatar
well, for one thing the efi head had a different combustion chamber than the old carbed head. yes, on most hemi heads the spark plugs screwed straight down. in that case the spark plug was directly between the intake and exhaust valves. it was kind of a design necessity. be careful, because there is more to spark plugs than how far they reach into the chamber. be careful the plug doesn't hit the piston at TDC. also, the heat range of the plug is important to keep fouling down. you'd do well to index the plug in a manner that the open end of the plug is facing into the chamber, rather than shrouding the spark. a search on indexing spark plugs will discuss this better.
__________________
  #6 (permalink)
Old 11-04-2009, 09:59 AM
recommend a plug
I was wondering if the guys with the older 300's--pre EFI--
could tell me which of the EFI plugs you are using, and what you gapping them at. I know the gap will vary from engine to engine, but wanted a starting point.
  #7 (permalink)
Old 11-04-2009, 01:16 PM
I think the model number for the EFI plug is probably pretty much the same regardless of the year. That is easy enough to check with a parts house though. I set the gap on mine at 50. If you feel like tinkering you can try anything from the stock gap up to 60 and see what works to your liking. They will tend to wear out a little faster with the wider gaps I hear.
__________________
  #8 (permalink)
Old 11-04-2009, 01:28 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
i use autolite coppers for my 95 with the 300. as far as gapping, i cant remember off the top of my head...i did whatever it says factory specs. are..
__________________
FORD......Found Off Road Diggin......
Quote:
Originally Posted by 6CylBill View Post
The only way this Bronco could get any better is if Jessica Alba and Lindsey Lohan made love and waxed this Bronco with their combined love juices.
Tags
extended , ford , gap , hyfire , plugs , reach , spark , sparkplug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
