hey guys. i need help with my charging guage. when i start the engine
the glow plug relay cycles on and off as normal. my charge guage goes
up and down when the relay cycles on and off. the guage returns to
14 volts after glow plug relay is done cycling. i replaced the battery
cables and starter relay. what else could cause this thanks alot
yeah,and Dave just explained that cycle to me the other day.
after the WTS light goes out,there is a short time where you hear the relay clicking,well what this is,is keeping your gp's warm,waiting for you to start the engine.thus the reason durring this time,for the volt meter to bounce up/down cus its sending that high juice to your gp's.
so really,to help keep your cranking power/battery life,it then appears logical to start the engine right away to get the batteries charging once the WTS light goes out.
but in short.like Dave says,its normal.so run her.
__________________
1993 F250 XLT HD 4x4 , 444ci N/A International Harvester IDI, E40D auto w/B&M shift kit & trans cooler, 1356 transfer case, 3.84:1 Effective gear ratio. 8'W X 9'L Stake body dump - Electric over hydraulic. Carfax clean w/49k original miles.
♠ Real Trucks Don't Have Spark Plugs.♠
the volt meter jumps from 14 volts to 8 volts up and down after i start the engine
until the glow plug relay stops clicking. my first 93 diesel. is this normal
thanks
steve
Yes.
__________________
Tony 1994 F250 XLT ext. cab,long bed,7.3 IDI factory turbo,4x4,manual hubs E4OD,4.10 gears, K&N air filter,PSD oil filter, TruxPort tonneau cover, 176,000 miles and counting. 88 Ranger 2.0, 5 speed,130,000 mi.,bought new.NC Chapter Member, IUE Retired, NRA Life Member.
that is your trucks way of saying "hey i work fine!" If it wasnt clicking at all then you would have a problem. Any issues starting?
__________________
1989 F350 Extra Cab 7.3l IDI NA W/C6 trans. No soup bowl, No plate, straight exhaust. Major mod is the 1994 F150 Body(LMAO) my truck makes me laugh and everyone else scratch their heads! Justice may be blind, but she is on my side 24\7, ask me how for your own peace of mind.
thanks
steve
I am used to gassers and I was not happy to see that at first, but you get used to it.
__________________
My V10 will out pull your PSD any day of the week.*
*If you have a stock 7.3.
Test must be under 4,000'
I will smoke the 6.0,6.4 and new 6.7 after I do the turbo mod and PI heads.
