Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 07:19 PM
joe f350's Avatar
joe f350 joe f350 is offline
joe f350 is gaining momentum as a positive member of FTE.
hight idle set way to hi
when i start my truck it runs at dang near wide open i know u can set the hi idle how do i go about doing that
__________________
85 ford f350 lifted 11 inch 37 6.9 t19 my freinds call it the panzer
  #2 (permalink)
Old 11-02-2009, 08:51 PM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually is starting off with a positive reputation.
http://www.ford-trucks.com/forums/88...s-at-idle.html
scroll to post 9
search is a beautiful thing!
__________________
87 CCD, 6.9 Banks Sidewinder turbo & ARP studs, fresh pump & injectors, str8 Pipe out the side, worked C-6, 4.56R&P & Laycock/GearVendors Overdrive
  #3 (permalink)
Old 11-02-2009, 08:58 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
warm the motor up and shut it off.
remove air cleaner.
unhook the fast idle speed solenoid.
use a jumper wire,from the + battery terminal to the solenoid terminal.
start and rev the engine a few times with this jumper connected,to set the solenoid.
now adjust the solenoid plunger in/out to adjust the rpms.
make sure its about 850-900 rpm's cold for your '85.(83-88) /for us with idi's with '89 and up,our cold idle wants to be 800-850/ then remove the jumper and put air filter back on.
your warm should be 650-700 rmps (this is all idi's) and should be set first before you set your cold.
my new diesel techbook is nice!
(i left out the safety bs and confirm with a devoted tach blah blah stuff lol.for those who dont know better-please set your e brake first. )
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #4 (permalink)
Old 11-02-2009, 09:04 PM
joe f350's Avatar
i don't have a tac or tac sensor hook up so i will have no clue where the rpms are
__________________
  #5 (permalink)
Old 11-02-2009, 09:11 PM
Quote:
If you don't have a clue where your RPMs are, than how do you know it's idling too high?
__________________
  #6 (permalink)
Old 11-02-2009, 09:18 PM
joe f350's Avatar
the sound form the motor and it all most pegs the throttle wide open
__________________
  #7 (permalink)
1993 Ford F-250
oh,no tach in your truck......well thats ok joe,just go by ear.basically,it wants to idle pretty slow when warm.just think about another diesel truck that you know runs right,and make sure its close to its idle speed.
for cold,its just going to be a bit faster thats all.so it sounds like the rpms are "slightly/moderately" to high for when its warm,know what i mean? just to the point,where it starts "running away" kinda.but not so high,where it sounds like its over revving either.just a good very fast pace rpm over warm.
your out in cali anyway,so dont worry to much if its not set high enough lol.just make it sound kinda higher than when its warm.
__________________
  #8 (permalink)
Old 11-02-2009, 09:20 PM
joe f350's Avatar
it takes about 5 mins to warn up and when it click theres a huge drop in rmps
__________________
  #9 (permalink)
Old 11-02-2009, 09:24 PM
1993 Ford F-250
yeah,thats what its supposed to do.
when you turn that cold idel down,your going to minimize the difference.she's over revving cold.
the difference should be good and noticeable.just not howling like crazy when cold lol.
__________________
  #10 (permalink)
Old 11-02-2009, 09:27 PM
joe f350's Avatar
oh it howl i make a video of it i dont want the motor to blow of grande after i get it back on the road
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
