Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 06:37 PM
kye kye is offline
kye is starting off with a positive reputation.
Missfire/studder while crusing at highway speeds?
I have a 97 f150 4.2,130k... While crusing at highway speeds(90-115km) and on back roads going up small hills and slight inclines my truck studders/missfires, If I stomp on the gas it clears up, but once I get back to crusing speeds the studder/missfire comes back. While driving intown truck runs smooth. It has new plugs,wires,fuel filter,cleaned MAF & IAC valve,fuel presure checks out too, also ran some good injector cleaner and the problem still occurs and is gettting worse. Could this be a bad coil pack ? I priced one out and its $240 from the local dealership. Has anyone else had a similar issue ? please let me know if you have any suggestions as this is getting expensive.. by the way no codes or engine light comes on ..
Thanks in advance,
Kyle
  #2 (permalink)
Old 11-02-2009, 08:28 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
how old is the transmission fluid? if it has not been changed you might have converter shudder problem. that normally happens at highway speeds, constant throttle.
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 190,000 miles
2002 Explorer 4 x 4 4.0 XLT - 120,000 miles
  #3 (permalink)
Old 11-03-2009, 12:42 AM
ole_smokey_88's Avatar
ole_smokey_88 ole_smokey_88 is offline
2002 Ford F-150
My Garage
ole_smokey_88 is starting off with a positive reputation.
Well for one i wouldn't give that much for the coil pack try a local oreillys and you can get one a lot cheaper and i think coil pack sounds like a pretty good chance is it throwing any codes ??
__________________
1988 F-150 5.8ltr aka "Ole Smokey"
1989 F-150 4.9ltr "For sale"
2002 F-150 5.4ltr aka "Newbi"
  #4 (permalink)
Old 11-03-2009, 07:00 AM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is starting off with a positive reputation.
I think I'm with Steve on this one - torque converter shutter. Changing the tranny fluid should clear it up. Misfire will usually cause a CEL.
__________________
'97 F150 4x4 XLT 4.6L 3.55 LS Supercab
  #5 (permalink)
Old 11-03-2009, 04:35 PM
eallanboggs eallanboggs is offline
eallanboggs is starting off with a positive reputation.
Also check fuel pressure and volume. Demand is highest under load.
  #6 (permalink)
Old 11-03-2009, 09:30 PM
kye kye is offline
My engine light came on today, After a month of dealing with this missfire I finally got a code P0304(missfire on cyl 4). I guess I'll have to pull the plug and wires on that cyl to double check them, any other ideas to solve this P0304 code?
On a brighter note I hope this rules out it being the transmission, It was rebuilt about 30 000 km ago at a heafty $2000 bill. Not wanting to do that again anytime soon lol
If it was a bad coil pack could it have set off the P0304 code ?
Thanks for the feedback,
  #7 (permalink)
Old 11-03-2009, 10:24 PM
steve(ill)'s Avatar
"if i stomp on the gas it clears up". normally that steers you away from the ignition system, but if you got the 304 code, then you got a problem there. that code shows up when it stumbles on #4 cylinder. it could be the plug, could be the coil, and could be a plugged injector. plug is an easy change and less cost. how about pulling #3 and #4 plugs and looking at them? see if #4 has any visual problem. switch #3 and #4 and see what happens. if code continues son #4, then i would consider the coil.
__________________
  #8 (permalink)
Old 11-03-2009, 11:26 PM
Changine plugs on these engines in a royal PITA so I wouldn't do only #4. I'd swap all 4 plugs on Bank 1 and the #4 COP. Pulling the fuel rail makes getting the COPs and plugs out manageable. Install new "O" rings(2 per injector). The "O" rings cost about 2 for a dollar. Put some oil on the new "O" rings before you install them. You can use the parts swap method, but it's so much work getting the plugs and COPs out it's not worth the extra work of removing and installing them a second time to correct a problem you didn't fix the first time.
  #9 (permalink)
Old 11-05-2009, 12:24 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 is starting off with a positive reputation.
The studder is missfire due to inability to fire lean mixtures under the specific conditions of light throttle and light engine load in that speed range.
Here is why:
At these conditions, the EGR is opened, timing advanced and fuel is cut back making the mixture very lean by intent and design, in the PCM program.
If the ignition can't fire the plugs under these lean conditions, a miss results until you apply more throttle.
At higher throttle openings, the EGR closes and everything is restored to normal with a richer mixture that the ignition can fire without a problem.
Usually it is a coil on COP motors but can happen to other configurations when there is a marginal ignition fault.
If you can make it happen and it follows the above action, you have that issue.
It only takes one cylinder to cause a problem like this
  #10 (permalink)
Old 11-05-2009, 08:36 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is online now
2005 Ford F-250
Johnny Langton has a good reputation on FTE. Johnny Langton has a good reputation on FTE.
Quote:
The 4.2L doesn't have COP's,and there's no need to pull the rail to change the plugs.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
Tags
2000 , 2002 , 2004 , 46 , 97 , bad , check , code , coil , engine , explorer , f150 , ford , misses , missfire , p0304 , pack , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
