Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-03-2009, 07:03 PM
whitesdford's Avatar
whitesdford whitesdford is offline
whitesdford is starting off with a positive reputation.
Those look pretty sweet. Are those dim-able? If not, are they pretty bright at night? Are those performax/ev2?
__________________
2001 CC 4X4 7.3 PSD, Auto, LB Dually
AFE Stage 2 intake
4" Straight exhaust
edge Attitude
Edge evolution
  #17 (permalink)
jdecker88's Avatar
jdecker88 jdecker88 is online now
Tip Coozy
jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold jdecker88 is a splendid one to behold
Now that is sexy Huck...
and yes everyone be Jealous over his 52K on the truck
I like my Isspros they are great gauges I wanted the Di Optix but when I found out they went to India I stuck with the true American made
__________________
Justin (JD)
2000 F-250 CC SB 4x4
Roadside Help NetworkDP-Tuner Guzzle's Truck Site
Pete's Custom Filter Covers Riffraff Diesel Performance
Quote:
Originally Posted by megawatt00 View Post
Kinda tough to embrace the dark side when your an electrician.
  #18 (permalink)
Old 11-03-2009, 07:10 PM
bigb56 bigb56 is offline
bigb56 is starting off with a positive reputation.
Is that LED for the glow plug relay?
  #19 (permalink)
Old 11-03-2009, 07:35 PM
strokersace's Avatar
strokersace strokersace is offline
strokersace has a good reputation on FTE. strokersace has a good reputation on FTE. strokersace has a good reputation on FTE.
Thanks for the pics Huck. But can you or does anybody have ones that show the Isspros AND the factory dash? That's the comparison I want to see. (I know that there's a very small part of your factory gauge in there, but still would like to see the full comparison).
Bigb- I'm assuming that's the GPR-LED.
Whitesdford- I think those are the performax/ev2 gauges but not sure.
__________________
02 F350 CC Dually 4x4 118K; Forged rods; headstuds; Tymar; coolant filter; 200 Amp alt; AIH Delete; Prepump/tank mods; 5" exhaust; IDM-140; x-monitor; Leveling kit; 06 leather seats f/r; 07 upfitters; custom dash; KR boards; rhinoed - FOR SALE
95 F350 CC Dually psd auto; Tymar Intake; 3" DP; Straight piped; Western Hauler - soon to be worked over...
  #20 (permalink)
Old 11-03-2009, 07:48 PM
hucka1a's Avatar
hucka1a hucka1a is online now
Welcome Home 776th!!!
hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE.
Quote:
Yes these are dim-able, controlled through the factory dimmer. I leave them all the way up.
Quote:
Yep, that's it.
I took seven pics and that was the best I got. I tried to get the factory cluster and the piller. I'll try to get some more tomorrow evening. These are the Performax, the EV2's look identical.
__________________
Huck PAA Member 66, E.T.A.P.S. Member
early 99 (11/24/98) F250, PSD, auto, 4x4, ec, short bed.6637/wrapped by Pete, CCV Mod, 6.0 Trans Cooler, MKO 4", '05 Power Seats(Thanks Scott), PMT2, Transgo Tugger, DP Tuner F6, diy oba, Isspro Performax, pyro, boost,Trans temp, and EOT mueckster 710 cap,True-Trac(Thanks Cory),diy Coolant filter.Riffraff Diesel Pete's Covers DP-Tuner Roadside Help Network
  #21 (permalink)
Old 11-03-2009, 08:29 PM
hucka1a's Avatar
I got board and tried it again. The pics still turned out fuzzy.
__________________
  #22 (permalink)
Old 11-03-2009, 08:37 PM
You camera must have a delayed shutter like mine. Sucks for nighttime pics but I haven't figured out how to get around it.
That's the best night comparison I've seen yet (even if it's fuzzy). Looks like the gauges are a shade lighter than the factory gauge, but that could be corrected with an additional dimmer for the pillar. Thanks again.
_____________
Edit:
Tried to rep ya but I'm still being held captive.
__________________
  #23 (permalink)
Old 11-03-2009, 08:46 PM
hucka1a's Avatar
They are brighter in that pic. No additional dimmer is required with these. I just haven't bothered with the dimming procedure to get them to match:
OPTIONAL: Adjust the backlighting to match the output of the factory gauges. This adjustment
should be completed when it is dark outside the vehicle.
a. Turn on the ignition, so that your Performax™ gauges are powered on.
b. Adjust the factory dimmer so that the factory instruments are at a comfortable lighting level.
c. Press and hold the mode button. After 5 seconds, the backlight level will begin to adjust,
getting brighter initially (until it reaches the brightest setting), then getting dimmer until it
reaches the dimmest setting, and repeating the cycle. Release the button when the
Performax™ gauge lighting intensity matches the factory instrument lighting intensity.
The lighting setting will be automatically saved in the ESP, and will now be the default. The
Performax™ gauge lighting will get brighter and dimmer as you change the factory dimmer
adjustment.
If you are just making this adjustment one time to match the factory gauges, you can temporarily run
mode switch wires outside the vehicle and into the cab (rather than permanently routing them
through the firewall).
__________________
  #24 (permalink)
Old 11-03-2009, 09:40 PM
reps sent to as many of you guys as I could, thanks for the info......sweet gauges!
__________________
AFE Stage 2 intake
4" Straight exhaust
edge Attitude
Edge evolution
  #25 (permalink)
Old 11-03-2009, 09:52 PM
jeff7825's Avatar
jeff7825 jeff7825 is offline
2001 Ford F-250
jeff7825 has a good reputation on FTE. jeff7825 has a good reputation on FTE. jeff7825 has a good reputation on FTE.
Those do look like a pretty close match. I really like my Dipricols, don't think you can go wrong with either though.
__________________
Jeffrey
2001 Ford F-250 Lariat CC SB 4x4 7.3 Powerstroke
Dipricol HPOP Gauge for sale: http://www.ford-trucks.com/forums/89...ure-gauge.html
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
