Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 04:49 PM
murph1 murph1 is offline
murph1 is starting off with a positive reputation.
2010 dash
bit the bullet and purchased a new f150...i really like the power out of the 4.6 3v...seems as though it has more power/torque than my old 99 5.4...
my question is ...what is the little square black thing on/in the dash...center of truck...towards the glass has 2 wires connected to it....
any ideas....
and will my daughters ipod work with the radio....i do not have the sync option,but there is a jack in the radio area for an mp3 type player...
thanks
  #2 (permalink)
Old 11-05-2009, 01:07 PM
BigJohn767's Avatar
BigJohn767 BigJohn767 is offline
2010 Ford F-150
BigJohn767 is starting off with a positive reputation.
any ideas....
thanks
Could it be the USB port? I don't have one in my 2010. I got the bare XLT but the book shows a USB port next to the MP3 port. You should be able to plug the iPod into the MP3 port from the headphone jack. I have a cheap MP3 player and that's how it works.
  #3 (permalink)
Old 11-05-2009, 02:59 PM
no...this is on the top of the dash...directly behind the square "tray" that they put on the dash, mine keeps my hat from sliding around....
I popped it out of the dash and cannot figure out what it is..just 2 wires connected to it..
  #4 (permalink)
Old 11-05-2009, 05:25 PM
JAC4X4 JAC4X4 is offline
JAC4X4 is starting off with a positive reputation.
it's a light sensor....cover it up and watch your instument panel light up.
  #5 (permalink)
Old 11-05-2009, 05:54 PM
berry1234's Avatar
berry1234 berry1234 is online now
berry1234 is starting off with a positive reputation.
Get a line out jack for your iPod. It puts a cleaner and louder signal to than the headphone jack.
http://i234.photobucket.com/albums/e...ock-2black.jpg
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
  #6 (permalink)
Old 11-05-2009, 07:29 PM
Quote:
i think that my hat covers it up most of the time...and i really haven't noticed the lights....but i will check that out first thing in the morning....i never really thought about it being something like that..
thanks
i 'll have to look for that line out jack for my daughters i pod...
but i dont think i can handle the Jonas brothers coming thru the radio in the truck...its bad enough already.........
thanks
  #7 (permalink)
Old 11-05-2009, 07:46 PM
BigJohn767's Avatar
2010 Ford F-150
You are right on! Not having an iPod, I didn't know they had a line out. My little cheapy only has an ear phone jack.
  #8 (permalink)
Old 11-05-2009, 07:58 PM
berry1234's Avatar
Quote:
The volume level is much louder and you don't get as much distortion. I see them on ebay for about $12.
__________________
  #9 (permalink)
Old 11-09-2009, 08:54 AM
BigJohn767's Avatar
2010 Ford F-150
I played with the light sensor by covering it up and found out a couple of things.
1. The sensor allows the dash lights to come on with the light switch in the ON or Automatic position.
2. The dash lights won't come on if the light switch is off.
3. Even with the lights in the ON position, the dash lights won't come on if the sensor thinks it's too light outside.
I want the dash lights on when I turn on the headlights whether it's light outside or not. Do I have to keep the sensor covered up to do this???
  #10 (permalink)
Old 11-10-2009, 05:32 PM
speed4tu speed4tu is offline
speed4tu is starting off with a positive reputation.
Yes but what is the point? If it is light outside you can see the buttons anyway.
  #11 (permalink)
Old 11-10-2009, 08:02 PM
BigJohn767's Avatar
2010 Ford F-150
Quote:
I find it hard to see the dash gauges when the light is a little dim. I would like to be able to turn the lights on and the dash lights to come on also, like most other cars.
  #12 (permalink)
Old 11-10-2009, 08:14 PM
doug527's Avatar
doug527 doug527 is offline
doug527 is starting off with a positive reputation.
if not mistaken the light switch has two settings, one to turn on and one to turn on using the sensor
  #13 (permalink)
Old 11-11-2009, 02:59 AM
broncobran68's Avatar
broncobran68 broncobran68 is offline
2009 Ford F-150
broncobran68 is starting off with a positive reputation.
Quote:
Yes you are right. The headlights can be turned on manually or automatically by the ambient light sensor.... But the dash and instrument lights can only be turned on by the sensor, regardless of the headlight switch position. It is like ford is trying to limit the their use to prevent some $.25 bulbs from going out prematurely.
I have found this annoying when it is sort of dark outside, like a rainstorm, but not dark enough for the truck to activate the lights. I feel like I need the headlights on, for safety reasons, and it can be hard to see the gauges. Overall it doesn't bother me that much just once in a while.
__________________
'09 F150 SCREW FX4. 2.5" AS Leveling kit. Line-x. 35" Toyo M/Ts on 18x9 Moto Metals
'68 BRONCO. 5.5" lift, 35s, 289 EFI, rollcage, durabak interior
  #14 (permalink)
Old 11-14-2009, 08:03 AM
bnk190 bnk190 is offline
bnk190 is starting off with a positive reputation.
Have the same complaint with the dash lights. Local dealer looked into it and there is no work around. At first they thought I was crazy when I told them this since they felt that the dash lights should be on when the headlights are on but later found that's not the case. In whatever he was looking at Ford even stated it's normal and not to try repairs.
Leads me to wonder if you disconnect the sensor and jumper the wires if they would then bypass the sensor.
I find it annoying in the morning when I'm heading east direct into the sun. Dash is bright but hard to see the speed.
  #15 (permalink)
Old 11-14-2009, 10:04 AM
BigJohn767's Avatar
2010 Ford F-150
I haven't tried it yet but does the sensor also control the auto headlights? If not, I can put a piece of electricians tape over it. It it does, then I either have to live with it or have the headlights on whenever I have the dash lights on (not really a bad thing.) Any thoughts on this???
Tags
2010 , dash , ford , light , sliding , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
