Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 03:08 PM
BigJake34452 BigJake34452 is offline
BigJake34452 is starting off with a positive reputation.
odd idle jump just started today
ok a little about the truck its a 00 with about 178k miles about 8k on fuel filter, 3k on oil/filter. ok so after idling at the bank today for about 10 minutes i noticed every 2-3 mins. my idle would jump approx. 300 rpms and slowly come down to idle RPM with out me doing anything. i have had a problem with when im coming to a stop it stays idled up a little and slowly comes down to idle but i cleaned the EBP sensor and tube on thursday and it hasnt done it since, but now this, any suggestions?
__________________
2000 F-250 supercab, LWB 2wd, 7.3L diesel, 6 spd manual, 170k miles, 6637, 4" turbo back exhaust.
  #2 (permalink)
Old 11-02-2009, 03:53 PM
clintbonnie clintbonnie is offline
clintbonnie is gaining momentum as a positive member of FTE. clintbonnie is gaining momentum as a positive member of FTE.
I think this is normal..it is built into the pcm.. Mine does the same thing..
I am sure if i am wrong, someone here will correct me.. !
__________________
Clint... Early 99, F350, 4X4, Auto, DRW, S-Cab, Gauges, Diablosport 60 HP, OilGuard, Tru-Cool, 5% Biodiesel, Shell Synthetic 5w40, Western Diesel TurboRamAir, MagnaFlow Exhaust, SSHPX, CCV Mod, Fuel Line/Tank Mod., Speed Bleeders, Bilstiens....
  #3 (permalink)
Old 11-02-2009, 06:32 PM
danskool's Avatar
danskool danskool is offline
Got temporary coach.
danskool has a great reputation on FTE. danskool has a great reputation on FTE. danskool has a great reputation on FTE. danskool has a great reputation on FTE.
This reminds me of when i was goofing around the the 10k resistor in the ICP.. My idle was all goofy. I wonder if you ICP is going south. It would hang the idle high while coming to a stop and it would slowly come down.
In the picture. In the middle, right hand side. ICP
__________________
Dan
2001 F250 XLT 7.3 PSD 2wd Auto 86k miles
Foil Delete. In tank fuel mod. TC Lockup & EBPV Brake. CCK. 50c Mod. Stancor GPR, LL delete, 6637/wpete, Stock muffler delete w/summit pass thru muffler.. FPR shim 65psi. Radiator hose wrap around. RV plug relocate to bed.
http://www.roadsidehelpnetwork.info/
  #4 (permalink)
Old 11-02-2009, 07:59 PM
Benny2002's Avatar
Benny2002 Benny2002 is offline
Dinosaur Powered
Benny2002 is gaining momentum as a positive member of FTE.
Mine does it too, not sure why. Only when the engines hot. Pull up to a light and it takes a few seconds for it to come down that last couple hundred rpms. Oddly enough if i turn my Air Conditioner off it will come down instantly not sure what it is. But its done it for a long time 75k miles.lol.
__________________
02 Stroke, CCSBSRW, Offroad Edition, L2 & Gold, Slightly Modified
  #5 (permalink)
Old 11-02-2009, 08:06 PM
triskit16's Avatar
triskit16 triskit16 is offline
2000 Ford F-250
triskit16 has a very good reputation on FTE. triskit16 has a very good reputation on FTE. triskit16 has a very good reputation on FTE.
Subscribing...mine does this too...
__________________
-Tristan
2000 F-250 XLT 4x4 Ext Cab SB Auto DP Tuner 60T 80E 120R 4" Turbo Back WW F650 Dash DiPricols MAC Intake Foil Delete CCV Firestone Bags LED...
  #6 (permalink)
Old 11-02-2009, 09:05 PM
mine does it when the a/c is off as well as on, i did post what the ipr and icp was doing on my scanner a couple of weeks ago and it was good but there is a little bit of oil on the sensor which made me think it was bad, do you think even though whatever the scanner recorded was in check it could be intermittent trouble with the sensor?
__________________
  #7 (permalink)
Old 11-02-2009, 09:20 PM
danskool's Avatar
Not sure on scanner data stuff. But if the sensor is bleeding oil into the connector. I would think the ICP is really going south. I would change it if i seen oil in the connector because i am afraid of walking.
__________________
Dan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
