Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 01:09 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
2008 Ford F-250
TexasRebel is gaining momentum as a positive member of FTE. TexasRebel is gaining momentum as a positive member of FTE.
Adding overloads
What would be needed to add overload springs?
Would it be as simple as adding the springs and the perches? Rivets are out of the question... How about grade 13 bolts?
__________________
2008 F-250 5.4L Reg. 4x2 6-spd 4.10
DIY Factory Upgrades: Installed TowCommand Brake controller, Upgraded to 4 spkr. Single CD/AM/FM w/AUX from 2 spkr. AM/FM, cab clearance lights, B&W "Turnoverball"
1977 C-10 Silverado
2002 1500 Silverado (sold )
  #2 (permalink)
Old 11-02-2009, 01:18 PM
Mustang6147's Avatar
Mustang6147 Mustang6147 is offline
Mustang6147 is gaining momentum as a positive member of FTE.
I have never heard of grade 13??? but when I replaced the rear spring hangers on a HDF250 and a F350 I used fine thread grade 8 bolts, and never had a problem.
I have my regular rack of springs, then about a 1 inch spacer, then my overload springs then the top plate.... and the perches are riveted to the frame allowing about an inch of travel befopre my helpers hit the rubber pad.
Its not like they hold the rear end in place, or take any torque, just upward pressure when loaded, and that shouldnt be a huge amount either...
__________________
06 SuperDuty 4x4 extcb 5.4, TorqShift, 4:10.
90 Mustang 9's, 750 HP Windsor. Ultratech Chassis
http://www.youtube.com/watch?v=pibt-TVgAx4
41 Plymouth 49 dodge flathead6 elec ign.
Sig Sauer P229 Two tone.
  #3 (permalink)
Old 11-02-2009, 01:25 PM
benbishop benbishop is offline
benbishop is starting off with a positive reputation.
Yeah you'll need about 2" longer ubolts, the overloads, and the pads. You should be able to bolt the pads on with grade 8 bolts(not sure what size the holes are).
Our 250 has the overloads, and our 350 doesn't, although it looks like the frame already has the holes to bolt on the pads. I'm replacing the spring packs this week on the 350, and adding the overloads. then I'll install the pads whenever I find some.
  #4 (permalink)
Old 11-02-2009, 02:20 PM
TexasRebel's Avatar
2008 Ford F-250
Class 12.9, "grade 13" it's all the same....
...scary as heck when they break.
__________________
1977 C-10 Silverado
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
