From the Linux box (don't add the dollar sign, that's your shell prompt):
$ /bin/cat /proc/meminfo
From your Windows box (two commands):
c:\> mem /d
c:\> cscript c:\windows\system32\pagefileconfig.vbs
EDIT: Post the output of the DOS commands in [ code ] [ /code ] tags (remove the
leading & trailing spaces). This will keep the spacing of the output when it's rendered in
browsers. Easy way: select all the text you've pasted, click the # button in the toolbar
(at least, it claims to work that way).
C:\>mem /d
Address Name Size Type
000000 000400 Interrupt Vector
000400 000100 ROM Communication Area
000500 000200 DOS Communication Area
000700 IO 000370 System Data
CON System Device Driver
AUX System Device Driver
PRN System Device Driver
CLOCK$ System Device Driver
COM1 System Device Driver
LPT1 System Device Driver
LPT2 System Device Driver
LPT3 System Device Driver
COM2 System Device Driver
COM3 System Device Driver
COM4 System Device Driver
000A70 MSDOS 001630 System Data
0020A0 IO 002290 System Data
KBD 000CE0 System Program
HIMEM 0004E0 DEVICE=
XMSXXXX0 Installed Device Driver
ASWMONDS 000250 DEVICE=
$ASWMON$ Installed Device Driver
000490 FILES=
000090 FCBS=
000120 LASTDRIVE=
0007D0 STACKS=
004340 COMMAND 000A20 Program
004D70 MSDOS 000070 -- Free --
004DF0 COMMAND 0004B0 Environment
0052B0 MEM 0003F0 Environment
0056B0 MEM 0174E0 Program
01CBA0 MSDOS 083440 -- Free --
09FFF0 SYSTEM 02C000 System Program
0CC000 IO 003100 System Data
MOUSE 0030F0 System Program
0CF110 MSDOS 0003E0 -- Free --
0CF500 MSCDEXNT 0001D0 Program
0CF6E0 REDIR 000A70 Program
0D0160 DOSX 0087A0 Program
0D8910 DOSX 000080 Data
0D89A0 MSDOS 017650 -- Free --
655360 bytes total conventional memory
655360 bytes available to MS-DOS
633136 largest executable program size
1048576 bytes total contiguous extended memory
0 bytes available contiguous extended memory
941056 bytes available XMS memory
MS-DOS resident in High Memory Area
C:\>
Cscript command:
Code:
C:\>cscript c:\windows\system32\pagefileconfig.vbs
Microsoft (R) Windows Script Host Version 5.7
Copyright (C) Microsoft Corporation. All rights reserved.
Host Name: SAMCOMP
Drive/Volume: C:
Volume Label: Hitachi 80GB
Location\File Name: C:\pagefile.sys
Initial Size: 384 MB
Maximum Size: 768 MB
Current Size: 384 MB
Total Free Space: 66680 MB
Host Name: SAMCOMP
Total (All Drives): Minimum Size: 2 MB
Total (All Drives): Recommended Size: 1915 MB
Total (All Drives): Currently Allocated: 384 MB
C:\>
__________________ 1981 F-150 Custom 302/C6 9"
FORD: The Best Never Rest!
Reason: Rest of info posted
__________________
my V10 will out pull your PSD any day of the week.
Quote:
Originally Posted by Jmeyer1990 ... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
I don't see how it's possible for them to get any worse.
Its not, the pistons popped out of the caliper.
Then the pedal went to the floor, then he sold it $1,000 less than it was worth.
__________________
Yeah, you win haha.
I think you need to mount that on your wall somewhere.
I should have hung it on my wall, I think I already sold it to the scrap yard.
After you just changed just one caliper and had no problems, I tried it and it is great.
soon as I redo the motor I will have it back on the road.
50 miles after I got it the motor blew a head gasket.
__________________
Well that's not good.
My truck is burning through oil too fast, I can't take it anymore. I parked it for 3 days and I swear the entire motor drained out onto my driveway.
No luck on fixing that leak yet
__________________ -Josh Nebraska Chapter Member ... but i kept losing service in Victoria's Sectret, so I gave up.
well I know the seal is bad also, but there is a leak on the pan itself. i can wipe the whole pan down, degrease it, and less than half a day later it will be covered in fresh oil.
The leak from the seal isn't all that bad actually, it seemed to have been worse when i got the truck, it's slowed down over time though.
