Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 11-07-2009, 02:48 PM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Jmeyer1990 View Post
well I know the seal is bad also, but there is a leak on the pan itself. i can wipe the whole pan down, degrease it, and less than half a day later it will be covered in fresh oil.
The leak from the seal isn't all that bad actually, it seemed to have been worse when i got the truck, it's slowed down over time though.
how bad is the oil pan gasket to change Josh?
I have done several, but all well the motor was out for something else.
__________________
my V10 will out pull your PSD any day of the week.
... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
  #47 (permalink)
Old 11-07-2009, 03:10 PM
doug1222556's Avatar
doug1222556 doug1222556 is online now
doug1222556 is gaining momentum as a positive member of FTE.
Well to solve the oil pan gasket leak- The most important thing is to make sure both surfaces are squeaky clean. To guarantee a seal apply some silicone to the pan, apply the gasket and put a bead on top. If the bottom of the block and the lip of the pan are both clean, it's virtually impossible to have a leak.
  #48 (permalink)
Old 11-07-2009, 03:43 PM
Jmeyer1990's Avatar
Jmeyer1990 Jmeyer1990 is offline
Jmeyer1990 is gaining momentum as a positive member of FTE.
It's a PITA with the motor in. No fun at all.
Quote:
I'll change it for a 3rd time sometime this week hopefully, I need the leak to stop before before the snow falls
__________________
-Josh
Nebraska Chapter Member
  #49 (permalink)
Old 11-07-2009, 03:52 PM
bill11012's Avatar
Do you have to unbolt the mounts and lift it with a hoist to get to it?
On TH350 and TH400 auto trany Chevy's, that is the only way to change the ATF & filter.
__________________
  #50 (permalink)
Old 11-07-2009, 03:57 PM
Jmeyer1990's Avatar
I have enough clearance to move it around the lovely ttb setup
__________________
-Josh
  #51 (permalink)
Old 11-07-2009, 04:11 PM
bill11012's Avatar
2wd Is called twin I beam. Twin Traction beam is 4wd.
One of the many things this site has teached me.
You took you location off?
It used to say right by the join date.
__________________
  #52 (permalink)
Old 11-07-2009, 04:19 PM
Jmeyer1990's Avatar
Yeah, I was getting some stalker-ish emails, and that idiot from Canada was contacting me again. So I decided to take it off.
I will make sure to call it a TIB instead from now on haha, thanks for the info.
__________________
-Josh
  #53 (permalink)
Old 11-07-2009, 04:24 PM
bill11012's Avatar
stalker-ish emails? WTF.
I call a TTB " 4wd twin I beam " once and stosh exsplaned it to me.
__________________
  #54 (permalink)
Old 11-07-2009, 04:32 PM
Jmeyer1990's Avatar
Yepo to the stalkerish emails.
Everything is nice and simple now. No more locations.
Go figure Stosh would be the one to explain it haha, speaking of him, has anyone heard from him in the past few weeks?
__________________
-Josh
  #55 (permalink)
Old 11-07-2009, 04:40 PM
bill11012's Avatar
I have not seen a post by him in about a month.
__________________
  #56 (permalink)
Old 11-07-2009, 05:55 PM
Jmeyer1990's Avatar
Turns out I need a new DVD drive for the desktop. Why are they so expensive now? Honestly? 65 bucks for a cd/dvd drive with burning capabilities is a bit messed up if you ask me.
__________________
-Josh
  #57 (permalink)
Old 11-07-2009, 10:27 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Quote:
Originally Posted by TheKirbyMan View Post
Code:
  *-display
       description: VGA compatible controller
       product: 82865G Integrated Graphics Controller
       vendor: Intel Corporation
Code:
Ubuntu 9.10
OK... Two more commands, I think these will be the last:
$ /usr/bin/lspci -nn | grep VGA
$ /sbin/lsmod | grep i915
EDIT: Just for grins, show me the first, say, 10 lines of the output from /usr/bin/glxgears
  #58 (permalink)
Old 11-07-2009, 10:50 PM
TheKirbyMan TheKirbyMan is offline
TheKirbyMan is starting off with a positive reputation.
lspci -nn:
Code:
00:02.0 VGA compatible controller [0300]: Intel Corporation 82865G Integrated Graphics Controller [8086:2572] (rev 02)
lsmod:
Code:
i915                  221064  2
drm                   159584  2 i915
i2c_algo_bit            5760  1 i915
intel_agp              27484  2 i915
video                  19380  1 i915
glxgears:
Code:
785 frames in 5.0 seconds
806 frames in 5.0 seconds
816 frames in 5.0 seconds
844 frames in 5.0 seconds
845 frames in 5.0 seconds
835 frames in 5.0 seconds
800 frames in 5.0 seconds
762 frames in 5.0 seconds
832 frames in 5.0 seconds
778 frames in 5.0 seconds
I have an older ATI Radeon 9200 AGP card that I was using in my previous computer, but this computer doesn't have an AGP slot. Just PCI...
__________________
1981 F-150 Custom 302/C6 9"
FORD: The Best Never Rest!
  #59 (permalink)
Old 11-07-2009, 11:53 PM
ctubutis's Avatar
Code:
It's too bad you can't use the ATI card.
Ya know, I first went down the path that you had suggested - poor
performance due to swapping things into & out of memory. But, it soon
occurred to me that that shouldn't be your problem and I turned my attention
to video, an area that can be problematic because video card manufacturers
can't or won't release their code to the open source world, resulting in things
getting reverse-engineered (another alternative sometimes is to use
commercially-provided, closed-source drivers from the manufacturers).
I have an Ubuntu 9.10 box at work, I upgraded it from 9.04; although that
upgrade was a serious improvement, it still has problems. Others I work with
have it, too, and are also saying the same thing. More than just the video.
The Ubuntu 9.x release(s) has/have been far from smooth, so much so that I
won't upgrade any of my home boxes to it (I run 8.04 on my primary desktop at
home).
I've got VERY limited experience with any of the Intel video chipsets (only 2-3
machines in the last 4 years) most of my experience is with NVIDIA & ATI
cards.
Despite that, there is plenty o' information out there about this Intel chipset
and its driver problems. Here's some of the stuff I've been reading:
HOWTO: Jaunty Intel Graphics Performance Guide - Ubuntu Forums
[HowTo] Fix Ubuntu Jaunty (9.04) Intel Graphics Problem | Ivan Kristianto Blog
https://wiki.ubuntu.com/X/Troublesho...telPerformance
https://wiki.ubuntu.com/ReinhardTart...telDriverTo2.4
[ubuntu] Intel 82865G Integrated Graphics Fix (Jaunty) - Ubuntu Forums
Although much of what I've been reading pertains to 9.04 (you're at 9.10) you
seem to have the problematic hardware & driver and are experiencing the
same issues that other people are complaining about, so you might try some of
the things people claim to have worked for them if you want to experiment and
perhaps learn some stuff.
Alternatively, you could install 8.04, it's FAR more stable.
I didn't read any of those things very closely but you should pay attention, you
could get yourself into a world of hurt (but only with the Linux installation, you
shouldn't hurt 'doze unless you seriously mess up and, say, wipe out your
partition table or somethin' similar). Even if you hose yourself up, some of
those docs out there walk you through recovering....
  #60 (permalink)
Old 11-08-2009, 01:00 AM
bill11012's Avatar
better than what my pc took to fix it.
The fan went out, the vid card got to hot and shorted.
The power supply died.
$325 later ( doing the work myself) I have it running better than ever, but I now have no sound.
I had to pull the mother board and I think I put the sound wire back on wrong.
__________________
Tags
iphone , oil leaks , random crap , snow , student dr's. , the v10 rocks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
