Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 11-06-2009, 10:54 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Quote:
Originally Posted by TheKirbyMan View Post
It's on a 2.4GHz Celeron with 1.2GB RAM, btw.
Post the output from the following commands:
From the Linux box (don't add the dollar sign, that's your shell prompt):
$ /bin/cat /proc/meminfo
From your Windows box (two commands):
c:\> mem /d
c:\> cscript c:\windows\system32\pagefileconfig.vbs
EDIT: Post the output of the DOS commands in [ code ] [ /code ] tags (remove the
leading & trailing spaces). This will keep the spacing of the output when it's rendered in
browsers. Easy way: select all the text you've pasted, click the # button in the toolbar
(at least, it claims to work that way).
  #32 (permalink)
Old 11-06-2009, 11:50 PM
Jmeyer1990's Avatar
Jmeyer1990 Jmeyer1990 is online now
Jmeyer1990 is gaining momentum as a positive member of FTE.
Thanks Grant, hows it going?
__________________
-Josh
Nebraska Chapter Member
... but i kept losing service in Victoria's Sectret, so I gave up.
  #33 (permalink)
Old 11-07-2009, 01:45 AM
TheKirbyMan TheKirbyMan is offline
TheKirbyMan is starting off with a positive reputation.
Linux box:
Code:
MemTotal:        1283692 kB
MemFree:          773452 kB
Buffers:           46968 kB
Cached:           263200 kB
SwapCached:            0 kB
Active:           284888 kB
Inactive:         186100 kB
Active(anon):     225708 kB
Inactive(anon):       16 kB
Active(file):      59180 kB
Inactive(file):   186084 kB
Unevictable:           0 kB
Mlocked:               0 kB
HighTotal:        399816 kB
HighFree:           1736 kB
LowTotal:         883876 kB
LowFree:          771716 kB
SwapTotal:       1686784 kB
SwapFree:        1686784 kB
Dirty:                12 kB
Writeback:             0 kB
AnonPages:        160816 kB
Mapped:            66224 kB
Slab:              20088 kB
SReclaimable:      10836 kB
SUnreclaim:         9252 kB
PageTables:         4408 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2328628 kB
Committed_AS:     697176 kB
VmallocTotal:     122880 kB
VmallocUsed:       11828 kB
VmallocChunk:     106624 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       4096 kB
DirectMap4k:       16376 kB
DirectMap4M:      892928 kB
XP box, "mem /d" command:
Code:
C:\>mem /d
  Address     Name          Size       Type
  000000                   000400     Interrupt Vector
  000400                   000100     ROM Communication Area
  000500                   000200     DOS Communication Area
  000700      IO           000370     System Data
                  CON                   System Device Driver
                  AUX                   System Device Driver
                  PRN                   System Device Driver
                  CLOCK$                System Device Driver
                  COM1                  System Device Driver
                  LPT1                  System Device Driver
                  LPT2                  System Device Driver
                  LPT3                  System Device Driver
                  COM2                  System Device Driver
                  COM3                  System Device Driver
                  COM4                  System Device Driver
  000A70      MSDOS        001630     System Data
  0020A0      IO           002290     System Data
                KBD        000CE0      System Program
                HIMEM      0004E0      DEVICE=
                  XMSXXXX0              Installed Device Driver
                ASWMONDS   000250      DEVICE=
                  $ASWMON$              Installed Device Driver
                           000490      FILES=
                           000090      FCBS=
                           000120      LASTDRIVE=
                           0007D0      STACKS=
  004340      COMMAND      000A20     Program
  004D70      MSDOS        000070     -- Free --
  004DF0      COMMAND      0004B0     Environment
  0052B0      MEM          0003F0     Environment
  0056B0      MEM          0174E0     Program
  01CBA0      MSDOS        083440     -- Free --
  09FFF0      SYSTEM       02C000     System Program
  0CC000      IO           003100     System Data
                MOUSE      0030F0      System Program
  0CF110      MSDOS        0003E0     -- Free --
  0CF500      MSCDEXNT     0001D0     Program
  0CF6E0      REDIR        000A70     Program
  0D0160      DOSX         0087A0     Program
  0D8910      DOSX         000080     Data
  0D89A0      MSDOS        017650     -- Free --
    655360 bytes total conventional memory
    655360 bytes available to MS-DOS
    633136 largest executable program size
   1048576 bytes total contiguous extended memory
         0 bytes available contiguous extended memory
    941056 bytes available XMS memory
           MS-DOS resident in High Memory Area
C:\>
Cscript command:
Code:
C:\>cscript c:\windows\system32\pagefileconfig.vbs
Microsoft (R) Windows Script Host Version 5.7
Copyright (C) Microsoft Corporation. All rights reserved.
Host Name:          SAMCOMP
Drive/Volume:       C:
Volume Label:       Hitachi 80GB
Location\File Name: C:\pagefile.sys
Initial Size:       384 MB
Maximum Size:       768 MB
Current Size:       384 MB
Total Free Space:   66680 MB
Host Name:                               SAMCOMP
Total (All Drives): Minimum Size:        2 MB
Total (All Drives): Recommended Size:    1915 MB
Total (All Drives): Currently Allocated: 384 MB
C:\>
__________________
1981 F-150 Custom 302/C6 9"
FORD: The Best Never Rest!
  #34 (permalink)
Old 11-07-2009, 09:28 AM
ctubutis's Avatar
Linux box:
OK, cool (I see DOS still behaves like DOS, your output looks very similar to mine
even though I have half your RAM).
Next command - on the Linux box, post the output of (you'll need to enter your
password so it can perform this action as God):
$ sudo /usr/bin/lshw -class display
These next commands don't need godmode privs:
$ /bin/cat /etc/issue.net
$ /bin/uname -a
  #35 (permalink)
Old 11-07-2009, 11:21 AM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
Quote:
pretty good.
Remember when I said my brakes where worse than yours?
[IMG]http://www.ford-trucks.com/forums/pi...ictureid=19733[/IMG]
Bad right?
This is the new truck.
__________________
my V10 will out pull your PSD any day of the week.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
  #36 (permalink)
Old 11-07-2009, 12:18 PM
doug1222556's Avatar
doug1222556 doug1222556 is offline
doug1222556 is gaining momentum as a positive member of FTE.
I don't see how it's possible for them to get any worse.
  #37 (permalink)
Old 11-07-2009, 12:23 PM
bill11012's Avatar
Quote:
Its not, the pistons popped out of the caliper.
Then the pedal went to the floor, then he sold it $1,000 less than it was worth.
__________________
  #38 (permalink)
Old 11-07-2009, 12:26 PM
Jmeyer1990's Avatar
Yeah, you win haha.
I think you need to mount that on your wall somewhere.
__________________
-Josh
  #39 (permalink)
Old 11-07-2009, 12:33 PM
bill11012's Avatar
Yeah, you win haha.
I should have hung it on my wall, I think I already sold it to the scrap yard.
After you just changed just one caliper and had no problems, I tried it and it is great.
soon as I redo the motor I will have it back on the road.
50 miles after I got it the motor blew a head gasket.
__________________
  #40 (permalink)
Old 11-07-2009, 02:08 PM
Jmeyer1990's Avatar
Well that's not good.
My truck is burning through oil too fast, I can't take it anymore. I parked it for 3 days and I swear the entire motor drained out onto my driveway.
No luck on fixing that leak yet
__________________
-Josh
  #41 (permalink)
Old 11-07-2009, 02:18 PM
Where is it leaking from Josh?
  #42 (permalink)
Old 11-07-2009, 02:23 PM
Jmeyer1990's Avatar
The oil pan.
I replaced the gasket twice now, new bolts, had it checked to make sure it wasn't warped, but still, it leaks like mad.
__________________
-Josh
  #43 (permalink)
Old 11-07-2009, 02:30 PM
From the front or the back? I'll bet you a nickle the reason you can't fix it is it's not the oil pan but a seal, especially if it's the back.
  #44 (permalink)
Old 11-07-2009, 02:43 PM
Jmeyer1990's Avatar
well I know the seal is bad also, but there is a leak on the pan itself. i can wipe the whole pan down, degrease it, and less than half a day later it will be covered in fresh oil.
The leak from the seal isn't all that bad actually, it seemed to have been worse when i got the truck, it's slowed down over time though.
__________________
-Josh
  #45 (permalink)
$ /bin/uname -a
lshw -class display:
Code:
  *-display
       description: VGA compatible controller
       product: 82865G Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 02
       width: 32 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:16 memory:f0000000-f7ffffff(prefetchable) memory:feb80000-febfffff ioport:ed98(size=8)
issue.net:
Code:
Ubuntu 9.10
uname -a:
Code:
sam@sam-desktop:~$ /bin/cat /etc/issue.net
Ubuntu 9.10
sam@sam-desktop:~$ clear
sam@sam-desktop:~$ /bin/uname -a
Linux sam-desktop 2.6.31-14-generic #48-Ubuntu SMP Fri Oct 16 14:04:26 UTC 2009 i686 GNU/Linux
__________________
Tags
iphone , oil leaks , random crap , snow , student dr's. , the v10 rocks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
