Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 11:37 AM
zman1202's Avatar
zman1202 zman1202 is offline
zman1202 is starting off with a positive reputation.
will not start and changed many things!
I have a 1986 ford f-250 6.9 liter ats turbo. It had a hard time starting a while ago would take forever to start and know it will not start at all. I changed the batterys two optima red top gel type, then i changed the glowplugs, then i changed the fuel filter and put some diesel kleen in it and then i changed the mechanical fuel pump, and the fuel line from the fuel pump to fuel filter and changed the air filter and it will not start still.
OOO yaa it did start with the fuel pump suction side hooked up to a 5 gallon tank of diesel. So not sure whats wrong with it.
Please help me out
__________________
1986 F-250 XLT Lariat 4x4, 6.9 Liter ATS Turbo, 4 inch body lift, 35" Procomp Xterrain Tires
  #2 (permalink)
Old 11-02-2009, 11:39 AM
zman1202's Avatar
oooo yaa and i changed the glow plug realy
__________________
  #3 (permalink)
Old 11-02-2009, 11:54 AM
f350fan1993 f350fan1993 is offline
f350fan1993 is starting off with a positive reputation.
Did you check the tank transfer switch in the dash and at the tanks? I had the same prob with mine around 3 mos ago, and believe it or not, that what it was.
  #4 (permalink)
Old 11-02-2009, 03:24 PM
7bicks 7bicks is offline
7bicks is starting off with a positive reputation.
How much fuel in the tank? The pickup screen has a tendency to break off on some years.
  #5 (permalink)
Old 11-02-2009, 06:22 PM
joe f350's Avatar
joe f350 joe f350 is offline
joe f350 is gaining momentum as a positive member of FTE.
i know i told u this before replace all lines form the lift pump back
__________________
85 ford f350 lifted 11 inch 37 6.9 t19 my freinds call it the panzer
  #6 (permalink)
Old 11-02-2009, 08:02 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
Quote:
yeah,mine went too.luckily for me (especially where im new to diesel's) is it was burning up and sounded like an electric fuel pump.i thought it had an electric pump right after i got the truck just a bit ago,and before i got to really looking everything over.
bypassed it for now.i think i'l just get one from a salvage yard.new price is foolish and aftermarket requires wire splicing(tho i dont really mind this,then it would be new-hmmm-yeah,now that i think about it,il probably do this.)
simple to bypass it to see if its not working tho yeah.-fuel gauge dont work tho darn it lol.
i just blew through the other valves to the rear tank,and made sure they where open-plugged the front tank into these and left wires off.very easy.but she would never run with that blocked up like it was.no fuel can get by.
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #7 (permalink)
Old 11-02-2009, 08:15 PM
1993 Ford F-250
Please help me out
your test of hooking up a fuel can directly to the engine told you a few things.
you dont have a problem with lift pump/injectors/glowpugs/relay/alt/starter/cables/etc/etc/etc/.and if you hooked in at your lift pump,and it runs fine,this means your problem is fuel lines/FSV(fuel selector valve) or bad pickup in fuel tank(s).
your problem then would mean fuel delivery.so you spent money on the wrong parts in other words see?
__________________
  #8 (permalink)
Old 11-02-2009, 10:24 PM
joe f350's Avatar
i told him this before
__________________
  #9 (permalink)
Old 11-03-2009, 01:25 AM
1993 Ford F-250
Quote:
oh you did lol.
hmm.well,sometimes we learn the hard way i guess.iv done worse things learning probably too lol.
the more i read,the more i understand how basic these IDI's are really.
man,its nice not having to deal with all that computer controlled bs!
this is great!
__________________
  #10 (permalink)
Old 11-03-2009, 10:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
The 86 truck had a water seperator mounted drivers side in the corner of the fire wall and fender, there is a pull ring on top of it to drain the water.
Those things are famous for not sealing and letting the lift pump suck in air.
Also the fuel line from the fuel tank selector valve to the front of the truck is metal, and could have a rust hole in it letting it suck air.
And last but not least, did the new lift pump have and arm bent almost 90 degrees or was it almost straight?
The straight arm units should have specific directions on how to install, they must be followed or lift pump or engine damage may result.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
